Mon Oct 23, 2023Total posts : 0
Sakshi
Sakshi
Topic: hii have newly plaster on wall. can i do putty work or we need to dry wall befo
hii have newly plaster on wall. can i do putty work or we need to dry wall before doing putty work.is there any solution that we can do putty immediately after plasterig and wall dont have crack .
wall putty
Last answer on 1/2/2021 5:22:50 AM. by leelindsey. Forum started by paresh
4627
time for paint and wall putty
2519
8880
2212
Painting interior walls
3992
2929
Plaster
2992
Wall Putty ,primer and paint
9541
Wall Putty and primer
3284
Wall Putty on exterior wall
3842
3084
1896
wall putty
Last answer on 7/3/2020 11:12:22 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
2373
7005
2924
3156
Basement waterproofing
9157
2414
COSTING AND STRENGTH OF WALL
Plastering
Plastering
Canvas
Canvas Wall Art
Tips for Dry Distemper Paint
Dry distemper is water based wall paint and is more durable than color wash. It contains a glue and tinted powdered ch..
Wall
Wall Decor
Checklist
Checklist for Painting Work
