What is acre Acre is traditional measure area unit, to measure the land in bulk mostly in agriculture and forestry. The abbreviation |
Right size cupola This article contains information about the size of cupola |
| Crystal Chandelier : Sparkle your Dining Crystal chandeliers give grace, lavishness and spark to your dining room. With a charming and elegant crystal chandeli.. |
| How to Build Stair Steps Stairs are an important part of our houses. At the time of constructing stairs you must consider the dimension, height.. |
| Bed Room Vastu Rest and relaxation are the two words that are foremost in ones mind when returning home from work. Talking of rest an.. |
| Vastu for Bathroom and Toilet Vastu tips for Bathroom help us determine the position of toilet seats, mirror, wash basin, and other fixtures in the .. |
| Vastu for Living Room Living room or Drawing room should be located in east or north direction. The ideal location of a living room depends .. |
VASTU SHASTRA Vaastu Shastra is an ancient system of designing the buildings. It helps in maintaining a dynamic balance between Form.. |
Which place is recommended for lifts in house according to Vastu Shastra? The lifts shall be installed in west-north west or east-south east |
Which place is recommended for parking in house according to Vastu Shastra? The parking is normally provided in the basement or at ground level or on stilts(elevated parts). |
Vaastu is Authentic Vaastu governs every movement of life. It imposes some certains rules on man for his well being throughout the life. |
Which side is recommended for Balconies/Verandahs in house acccording to Vastu shastra? Balconies/Verandahs shall be in north-north east, north east-east,south-south east or west-north west |
What is recommended size of water closet as per Vastu norm? The area of water closet shall |
Which place is recommended for security hut in house according to Vastu norm? The security hut should be placed in such a manner that the guards face east or north |
