Mon May 02, 2011Total posts : 2
nishant shah
nishant shah
Topic: i already have underground water tank in south direction now is there any remedy
i already have underground water tank in south direction now is there any remedy for this
Mon May 09, 2011Post  #1
Nikita
Nikita
Post subject: Underground water tank
Hello Nishant,
The best place for digging the sump is the North-east of the plot. This leads to increase in wealth, prosperity and knowledge. While digging the sump, an axis should be drawn from the Northeast corner to southwest corner. The sump should be dug to the right or left side of axis. The sump in east of northeast is most beneficial and the sump in north of northeast is also good.
Regards:
Nikita.
Fri Sep 19, 2014Post  #2
Unoara Design Hub
Unoara Design Hub
Dear Nishant,
Though Vastu is essential, it depends more on your site conditions and the micro climate around your property. If the site slopes towards the South, then irrespective of where to how down, the lowest point would turn out to be the South, so please understand that it is essential to know if the location is causing any problems and if yes then try to pinpoint scientifically rather than superstitiously. Having said that we ourselves use Vastu and Fengshui science, but as we said it's science based on SUN, WIND, WATER, ENERGY and EARTH.
All the best!
UNOARA DESIGN HUB
2634
5056
2119
2187
2219
3369
5207
2450
2058
4480
3370
2419
2959
Last answer on 9/1/2015 2:51:50 AM. by JAI PRAKASH. Forum started by sher singh daulta
13539
6272
Water Tank Quality
2024
1774
1572
I want tp build a plot in south facing direction. please suggest the disadvantag
Last answer on 2/7/2016 10:40:46 PM. by JAI PRAKASH. Forum started by jitendra sinha
15
17
Vastu for Water Tank
Preventive
Reasons of dampness
60
60 Tips to Save Water
Sewerage
Sewerage & Plumbing System
Water for Construction
