i am fitting ac in new home what mm size of wire i should use for electrical sup
Fri Mar 13, 2015Total posts : 1
Topic: i am fitting ac in new home what mm size of wire i should use for electrical sup
i am fitting ac in new home what mm size of wire i should use for electrical supply 2.5 mm or 4 mm also do price comaprison.
Sat Mar 14, 2015Post  #1
1-1.5 tonne - 4 mm
2.0 tonne - 6 mm
2.5 mm can be used in place of 4mm if the brand is good like havells, anchor etc.
The price varies brand to brand.
18409
2974
2090
wiring
Last answer on 5/19/2015 9:10:27 PM. by JAI PRAKASH. Forum started by ananth
wiring
Last answer on 5/19/2015 9:10:22 PM. by JAI PRAKASH. Forum started by ananth
2030
2351
electrical installation
Last answer on 11/27/2021 2:32:14 AM. by Navneet Jharia. Forum started by brajesh pandey
2483
1966
2282
Ac and Electrcial
1919
2473
My home is T type fernt size Is 10.75 *30 after 30 fit size is 39*53 pl advoise
Last answer on 3/16/2011 2:32:10 PM. by Mohini Sharma. Forum started by pukhraj tater
2864
2888
Last answer on 9/30/2020 7:45:37 AM. by Vijay Mishra. Forum started by SCK
1946
REQUIRE HOUSE PLAN FOR 55*20
Last answer on 1/21/2021 4:00:29 AM. by S L Gupta (Civil Engg). Forum started by SUNDER KUMAR
1837
I want to open the new showroom for saree and laddies wear kidds wear my shop si
Last answer on 9/23/2015 11:13:55 PM. by sanjay agarwal. Forum started by giriraj singhal
2617
Window position on wall
2559
Factory Main Door
2920
30
hUsBaNd =//=wIfE[[ 91-8769373431]]=//=Divorced problem solution
Last answer on 1/7/2025 11:20:19 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:20:12 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:56 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:49 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:43 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:37 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:30 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:24 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:16 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:10 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:04 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:58 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:51 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:45 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:38 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:32 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:26 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:18 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:11 PM. Forum started by rupeshji
Husband Wife 918769373431~LoVe PrObLeM SoLuTiOn
Last answer on 1/7/2025 11:17:54 PM. Forum started by rupeshji
Electrical
Earthing
Electric
Electric Shock Proof Home
Central
Central Air Conditioner
Central air conditioners are good option for big houses or large building. And proper functioning of central air condi..
What is binding wire
Electric
Electric
Switches
Switches and Sockets
