i have 3712 sq feet of plot the lenth is 64 and the deapth is 54.it is a weast f
Thu Oct 24, 2013Total posts : 1
nikhil
nikhil
Topic: i have 3712 sq feet of plot the lenth is 64 and the deapth is 54.it is a weast f
i have 3712 sq feet of plot the lenth is 64 and the deapth is 54.it is a weast facing corner plot.there are two side road.i want to make it as a gujrati traditional pattne.as per vastu. it should be a duplex house.with four bedroom.kitchen.living room,dianingroom,storeroom,poojaghar.three master badroom.
Fri Oct 25, 2013Post  #1
Dear Mr.Nikil
have 3712 sq feet of plote the lenth of plote is 64 and 58 is the deapth it is
Last answer on 11/21/2013 10:17:04 AM. by S L Gupta (Civil Engg). Forum started by nikhil
2474
4449
if y have t junction plot what is the solution i am having south facing plot wit
Last answer on 8/21/2014 2:37:19 PM. by Dilavarsinh Vaghela. Forum started by sudhir samdani
3474
2305
1334
2353
Sir please help me my plot size 20 ×54 Feet h sir give best ghar ka naksha
Last answer on 5/3/2016 12:28:17 AM. by JAI PRAKASH. Forum started by Krishan
2972
duration of constucting home
2878
2330
i am constructed the circular wall of 30 feet dia.,30 feet height
Last answer on 1/6/2022 10:11:07 AM. by S L Gupta (Civil Engg). Forum started by shivprasad
2324
2433
I have a plot size 47 x 67 feet I am planning for 4bhk house . please guide me
Last answer on 1/26/2011 11:49:31 AM. by Rajeev. Forum started by A Santosh
3426
3241
It's very urgenti am constructing a house in hyderbad.East face plot(36*50)36 wi
Last answer on 10/4/2021 9:18:14 AM. by madhusudan. Forum started by varala prasad babu
2409
i want to house plan for 1 floor size 17 feet width and 39 feet lenth
Last answer on 5/29/2017 5:57:46 PM. by Saurav anand. Forum started by rajusapra
2210
34×64 north facing plot plan
Last answer on 7/21/2020 6:05:44 AM. by S L Gupta (Civil Engg). Forum started by Shreekant pathak
2123
PLOT SIZE 40*64 IS GOOD ?
Last answer on 7/4/2020 2:00:23 AM. by S L Gupta (Civil Engg). Forum started by SIVAKUMAR
3510
2224
17
What is acre
Designing
Designing a Foundation
