Thu Dec 25, 2014Total posts : 1
Topic: i havent given hole for water passage on roof during roof work how to sort out t
i havent given hole for water passage on roof during roof work how to sort out this problem can drill work?
Fri Dec 26, 2014Post  #1
Dear Ashok
         One option is drill hole in roof and made its size with chisel cutting, if M. S. steel bars comes in hole than cut the steel bars. If you have outer wall with road or street than fix rain water pipe on wall and no need of drilling roof.
1791
1331
Extension of rcc roof like L shape and passage of air through air holes.
Last answer on 10/22/2020 11:37:02 PM. by S L Gupta (Civil Engg). Forum started by vinu
1906
2247
2989
3802
2413
2232
2234
1874
2238
Last answer on 1/4/2022 11:02:33 PM. by S L Gupta (Civil Engg). Forum started by nagaraju kakani
5222
3163
APP membrane
8419
Roof Beam crack
2912
RCC ROOF LEAKAGE
Last answer on 12/5/2012 1:40:32 PM. by S L Gupta (Civil Engg). Forum started by sivarajen
3133
roofing on open terrace
1792
Wehave 93 years old tiled roof with norh face. Behind of this recently construct
Last answer on 5/1/2015 1:40:37 AM. by JAI PRAKASH. Forum started by balagangadhar
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
