i m planning to build a 900 sq feet single storeyed house in coastal north karna
Sun Jan 04, 2015Total posts : 1
nitinkumar
nitinkumar
Topic: i m planning to build a 900 sq feet single storeyed house in coastal north karna
i m planning to build a 900 sq feet single storeyed house in coastal north karnataka. It would be a load bearing structure , built with plain laterite blocks. it would be a 2 bedroom hall kitchen structure with mangalore tiles. could someone tell me the approx building cost involved?
Sun Jan 04, 2015Post  #1
Post subject: 900 sq feet single storeyed house in coastal no...
Dear Nitin kumar , The cost of construction of such type of house may vary according to materials and labour cost .at your state.also finishing work like wood work,flooring,sanitary & water supply ,electrification etc. are cost effective.....A simple construction costs about  RS.1200 to 1500 per Sq.ft.approx...Regards
2812
north seeing house 900 sq.ft house models
Last answer on 4/16/2012 2:06:19 PM. by Gunjan Utraja. Forum started by usha
2005
if any have photos of best house plans with 900 sq.ft plse send it
Last answer on 7/27/2016 2:33:34 PM. by Beenu Phogat. Forum started by ram
2330
5833
Last answer on 7/3/2020 9:39:24 PM. by ramu771964. Forum started by RAKESH DIXIT
2878
3635
2181
we have 900 sq ft space want to build,kindly suggest for some map....vastu accor
Last answer on 6/23/2015 3:22:38 PM. by seema tyagi. Forum started by Raj
2364
4385
2972
duration of constucting home
3147
i built one house so pls help me 27x42 sq feet
Last answer on 12/23/2011 5:00:58 PM. by FARZAN. Forum started by suryaprakash
6199
share plan for 900 sq ft... 22.5 x 40 (depth)
Last answer on 11/23/2015 1:57:34 AM. by JAI PRAKASH. Forum started by navneet
15137
24/45 north facing la naksa send karna
Last answer on 6/21/2016 1:02:51 AM. by S L Gupta (Civil Engg). Forum started by anilkumawat
3165
I want to know the budget for constructing a house of 600sq.ft(G) and 900 sq.ft(
Last answer on 12/31/2020 2:22:31 AM. by narendra barde. Forum started by vidhya
10835
my plot is 20x60 feet north facing suggest me a floor plan for duplex house
Last answer on 7/4/2020 2:33:24 AM. by pmlaks. Forum started by Raghothaman
1781
sir.iam in tamilnadu.we started to plan build new house in 900 sq.ft.i need some
Last answer on 7/27/2016 2:34:54 PM. by Beenu Phogat. Forum started by madhu
1724
i have 20 feet north in front of and 65 feet south plot please give house plan g
Last answer on 10/25/2016 11:38:36 AM. by S L Gupta (Civil Engg). Forum started by vijay pathak
10312
900 Sqft column required
Last answer on 7/21/2021 11:11:14 AM. by S L Gupta (Civil Engg). Forum started by Shivaraj
23
27
What is acre
Orientation
Orientation of Building
How to Design a Garage
Environment
Environment Friendly Houses
