i wana construct a 18X14 feet hall single story .Is 9x9 column at corner os suff
Fri Sep 13, 2013
manishkumar
Topic: i wana construct a 18X14 feet hall single story .Is 9x9 column at corner os suff
i wana construct a 18X14 feet hall single story .Is 9x9 column at corner os sufficient with no live load
Fri Sep 13, 2013
At corner 9''x 9'' column is sufficient but in 18' length middle column is also required.
Thu Sep 19, 2013
manishkumar
Post subject: Thank you
Thank you Gupta ji.
With the help of these knowledge we are now able to supervise our own home construction and undrstand the calculation behind it.
thanks again for prompt answer.
Manish
Last answer on 4/6/2017 10:05:57 PM. by
Saurav anand
prashant
4756
Last answer on 6/29/2009 12:59:57 PM. by
ningappa c k
chinu
4529
Reagarding Coulmn Pillar
Last answer on 9/29/2015 11:01:46 AM. by
Amit Kumar
1343
i want built my home.dimensions 36 by 34 feet.i wana have a1 kitchen3 rooms1 sto
Last answer on 10/12/2016 11:21:28 AM. by
arshid
3828
Last answer on 2/15/2013 11:15:40 AM. by
prassant kumar
prassant kumar
9803
nasad
2784
Last answer on 6/17/2013 5:17:52 PM. by
g.s.rajan
3451
Last answer on 5/19/2015 9:12:55 PM. by
Wiki
1476
Last answer on 12/2/2016 11:43:21 AM. by
ranjeet
1550
Want a front elevation of 32* 50 floor plan single story
Last answer on 10/12/2016 11:28:31 AM. by
avtarbagha
2538
i want to see elevation of single story bunglow
Last answer on 5/28/2013 5:05:45 PM. Forum started by
Nilesh Mehta
1522
Length of my hall if about 16 feet. So the masan while constructing the hall ad
Last answer on 4/17/2010 5:04:41 PM. by
Ajit Tareeka
R Sankar
22843
Can i have front elevation for Indian homes with single story
Last answer on 7/4/2020 3:07:35 AM. by
sanjeevv.verma
3962
this is execelant front view,looking varities of front elevation for single sto
Last answer on 12/27/2020 8:48:44 PM. Forum started by
Thakur Pattanaik
1701
KINDLY SEND 24* 45 CORNER HOUSE FRONT AND CORNER ELEVATION 3 STORIES
Last answer on 2/7/2017 12:59:59 PM. by
balwinder singh
1312
Last answer on 7/28/2020 12:37:49 AM. by
vishal singh
2268
i am constructed the circular wall of 30 feet dia.,30 feet height
Last answer on 1/6/2022 10:11:07 AM. by
shivprasad
2914
duration of constucting home
Last answer on 7/3/2020 11:35:16 PM. by
Last answer on 12/10/2014 10:12:46 PM. by
Vishnukant Phafat
1370
Pandit Sahil Sharma Ji
216
71
73
90
75
73
74
76
164
71
70
73
78
74
65
61
73
66
Corner Bath Designs
What are various types of windows?
Various types of windows are mentioned below: 1. Awning window 2.Casement Window 3.Single Hung Windows
