Home -> Forums -> Construction -> Laundary -> i want economical and attractive flooring for hospital setup and some goodloking
Mon Mar 08, 2010Total posts : 3
kanchan bhoite
kanchan bhoite
Topic: i want economical and attractive flooring for hospital setup and some goodloking
i want economical and attractive flooring for hospital setup and some goodloking easy to clean fiooring for home pl give me some tips
Wed Mar 10, 2010Post  #1
Ajit Tareeka
Ajit Tareeka
Post subject: option for hospital flooring
Options are;
Vinyl
Kota Stone
Rubber flooring would be the best as it require less maintenance. Kota stone floor require regular interval mopping. On vinyl flooring you cannot move heavy objects.So rubber would be the best option
Wed Mar 10, 2010Post  #2
Post subject: Reply- I want economical
Dear Kanchan,
For commercial building like hospital, ceramic glazed tile flooring is good choice. For house you may choose flooring between marble stone flooring, ceramic glazed tile flooring or wooden flooring. For more information about flooring you can take help from Flooring section of  website Gharexpert.com, available at link below:
http://www.gharexpert.com/category/2/Flooring-0.aspx?PL=2&Estimator=
S.L.Gupta
Wed Mar 10, 2010Post  #3
Ajit Tareeka
Ajit Tareeka
Post subject: Please ensure
I don't think that tiles are suitable for hospitals.As you know that hospitals used to be crowded. I have seen hospitals with tile flooring, floor always look so dirty. I have also seen hospitals with kota stone flooring but looks better than tile flooring. On tile floor, dirt  shines.
You can opt granite floor which is more better than tile. I would not recommend you tile flooring. On tile flooring you cannot move heavy objects. There is  grout problem in tiles. I have seen it looks dirty and horrible.
Please ensure before purchasing the flooring.
Ultimately rubber flooring is the best option for hospitals. There is no problem with dirt, maintenance, life, etc.
Laundary-Construction Questions (19)
1727
Mirror setup in living room?
Last answer on 1/27/2015 7:24:52 PM. by JAI PRAKASH. Forum started by ajay Doysuree
2514
hospital ke lobby me konse floorig karna chaiye.
Last answer on 12/8/2021 11:21:30 PM. by Gunjan Utraja. Forum started by nitin bardia
2811
IN independent house - min how much rcc thk required and re informcement steel spacing and size of steel
Last answer on 3/1/2013 6:22:20 AM. by Maharshi. Forum started by tkalaiva
2669
1850
can i use vetrified floor tiles (600 x 600 )for my hospital wall( dado )instead
Last answer on 1/29/2011 1:47:18 PM. Forum started by vikram khot
4810
PLEASE SEND ME SOME MORE MODERN AND ATTRACTIVE PICTURE OR LINK (URL) OF CORPORAT
Last answer on 2/26/2022 5:07:11 AM. Forum started by abhijit
3360
Lighting Tips
Last answer on 12/31/2020 2:04:03 AM. by VIPUL HASIJA. Forum started by Gomsi Arora
1313
Economical and reliable choice of type of exterior staircase to the rented 1st floor of house.
Last answer on 12/26/2016 1:12:50 PM. by S L Gupta (Civil Engg). Forum started by vinu
2586
flooring
Last answer on 5/31/2012 7:13:24 PM. by watson. Forum started by pallubc2
3805
cpvc pipes v,s gi pipes
3118
concrete brick or clay brick
3437
Any interior decorators in Hyderabad quoting economical rates for quality service?
Last answer on 8/13/2015 11:52:23 PM. by JAI PRAKASH. Forum started by Murali
1878
column
1702
Last answer on 7/3/2020 11:20:06 PM. by S L Gupta (Civil Engg). Forum started by PCR.Manohar
2689
DOORS
2263
Last answer on 7/4/2016 5:42:09 PM. by S L Gupta (Civil Engg). Forum started by Aniket
2925
Skylights
Last answer on 12/31/2020 2:07:37 AM. by Rajan. Forum started by hemapradeep
3441
Last answer on 10/8/2021 12:49:42 AM. by Navneet Jharia. Forum started by vgshekar1
1523
70 feet width east face commercial building. wanted good attractive design for 3
Last answer on 3/23/2011 9:05:14 AM. Forum started by GVRao
A
Hotel
Hotel reception designs
The texture, color and shape of the reception in your hotel must reflect a mood that is appropriate for its function. ..
Terrazzo
Refinishing Hardwood Floors
Checklists for flooring
Drawing
Drawing Room Flooring
Epoxy
Epoxy Flooring
Epoxy flooring can be defined as several layers of any type of epoxy resin that is applied on a floor surface. This ty..
Italian
Italian Marble Flooring
Basement Flooring
