i want to construct a house.is it better to construct it on lump sum turnkey bas
Mon Aug 31, 2015Total posts : 4
MELA RAM SAINI
MELA RAM SAINI
Topic: i want to construct a house.is it better to construct it on lump sum turnkey bas
i want to construct a house.is it better to construct it on lump sum turnkey basis or should hire a contractor for construction only,please advice me
Tue Sep 01, 2015Post  #1
Nowadays it is good to go with turnkey basis. Take the list from your vendor. They bear the architect and drawing charges which is also good. They provide good planning. It will save your time. They give free vastu advice with visit from experts. The rates varied as per the material you selects.
Tue Sep 01, 2015Post  #2
Dear Mela Ram
          If you have no time for construction than give the contact of building to any contractor on lump sump basis but this has disadvantage that contractor charge 25 to 30% more and beside cost the specification used are inferior.
For this you should prepare drawing in advance and than got detail estimate in this way you are able to know the cost and have better option to bargain with contractor as you have detail with you and also talk with contractor for specification.
 The second option is  to hire contractor on labor rate and arrange material on your own, This will be economical and specification will be according to your requirement.
http://www.gharexpert.com/articles/Start-Construction-1528/Guidelines-while-Starting-Construction_0.aspx
http://www.gharexpert.com/articles/Start-Construction-2368/List-construction-activities-in-sequence_0.aspx
http://www.gharexpert.com/articles/Start-Construction-1973/Gharexpert-can-save-you-money-during-construction_0.aspx
Wed Sep 02, 2015Post  #3
where are you located?
Wed Sep 02, 2015Post  #4
If you want good quality construction, then hire a consultant, hire a contractor for labor only, purchase all material by your own. turn key option is not good.
It's very urgenti am constructing a house in hyderbad.East face plot(36*50)36 wi
Last answer on 10/4/2021 9:18:14 AM. by madhusudan. Forum started by varala prasad babu
2196
1570
3462
1180
Does polyester shrink when it's washed and dried?
Last answer on 1/23/2022 6:06:52 AM. by Celly Swehykol. Forum started by Rolly
2474
2223
New Construction
1809
Last answer on 1/27/2016 12:04:33 PM. by S L Gupta (Civil Engg). Forum started by A Ghosh
2647
2047
Are there are issues to paint a newly constructed house or is it better to wait
Last answer on 1/30/2013 11:36:55 AM. by S L Gupta (Civil Engg). Forum started by aiyer
3626
chair in slab steel
Last answer on 4/23/2014 8:34:50 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
882
How can I write to my employees that it's time to reunite with colleagues in the
Last answer on 1/5/2022 12:45:37 AM. Forum started by Sally
2969
NEED A ADVICE ABOUT EAST FACING PLAN
Last answer on 7/3/2020 9:50:41 PM. by JAI PRAKASH. Forum started by chandru
3443
Type of Cement
3025
Request for Elevation ideas.
Last answer on 7/2/2020 9:41:17 PM. by S L Gupta (Civil Engg). Forum started by kolarphani
2261
Specification of Steel
Last answer on 12/29/2010 12:48:24 AM. by dhanaraj. Forum started by MEHBOOB
3325
4010
sir i am going to construct 30 to 40 house at my site. i am interested to discus
Last answer on 12/18/2021 1:23:23 AM. by Amit Hasija. Forum started by jiten adesara
KITCHEN
"KITCHEN"THE POWER HOUSE
SOUTH-EASTCORNER IS SUPPOSED TO BE THE PLACE OF LORD AGNI,GOD OF FIRE.
Painting
Environmentally
