Fri Jul 13, 2012Total posts : 3
rajeev
rajeev
Topic: i want to know the concrete mix quantity for column of 8x12 for 10 feet height
Sat Jul 14, 2012Post  #1
Dear Rajeev
           In RCC column use cement concrete mix 1:1.5:3.
Sat Jul 14, 2012Post  #2
P. Panchal
P. Panchal
Total volumn of ur column is ( 0.66 x 1 x 10 feet ) = 6.6 cubic feet.
Concrete mix will be 1 : 1.5 : 3
You require one part of cement = 6.6 x 1 / 5.5 = 1.2 cubic feet
Sand required                             = 6.6 x 1.5 / 5.5 = 1.8 cubic feet
Aggregate required                   = 6.6 x 3 / 5.5  =  3.6 cubic feet
Sun Oct 12, 2014Post  #3
 the quantity of column is  6.6 cft or  0.19 cum
for this you need  cement =2 bags including  wastage  for M-20 G concrete.
1457
2135
READY MIX PLASTER
20123
1340
2568
1857
13755
3769
concrete mix design software
6548
6462
2629
Roofing elevation
Last answer on 12/24/2014 4:28:01 PM. by S L Gupta (Civil Engg). Forum started by Sai Pavana
1895
Structural design
Last answer on 7/3/2020 10:29:46 PM. by S L Gupta (Civil Engg). Forum started by Akhil George
1530
Last answer on 12/2/2016 11:43:21 AM. by S L Gupta (Civil Engg). Forum started by ranjeet
2676
2329
i am constructed the circular wall of 30 feet dia.,30 feet height
Last answer on 1/6/2022 10:11:07 AM. by S L Gupta (Civil Engg). Forum started by shivprasad
3075
RCC roof
1871
I have 10 feet width and 84 feet depth plot, how I construction students lodge
Last answer on 10/4/2015 12:49:06 AM. by JAI PRAKASH. Forum started by chandan
3622
Concrete Mix Ratio
Ready
Ready Mix Concrete
CONCRETE
