Home -> Forums -> Construction -> Ground work -> i want to know the procedure of construction.............
Wed Sep 26, 2012Total posts : 1
sweta agrawal
sweta  agrawal
Topic: i want to know the procedure of construction.............
guys tell me what is the 1st step to take when a building is to be made about 2000sq .ft............can any body guide me step by step bacause i dont know what is the procedure but i want go through over all this to have the knowledge about........that is why i have taken the project...............
Thu Sep 27, 2012Post  #1
kamal
kamal
Site inspection&work-include detail inspection of present conditions at site, whether land is vacant or not...if not then u need to organise property demolishiling plan..utilities need to be disconnected prior to demolition of a house and hooking up temporary electricity service bcaz demolition is a messy and sometimes dangerous..n lot of things..
Excavation and foundation - Include digging a hole for the foundation, setting and pouring the foundation, installing plumbing pipes, pouring the concrete floor of the home, digging trenches for utility lines, waterproofing the basement walls and grading etc.
Framing/Roofing - Installing steel beams, erecting a wood/jack-lops structure and installing windows and doors frames, Applying roofing materials and installing siding, an outdoor deck etc.
den Mechanicals works, Interior finish work etc...
2881
1830
I would like to know the procedure to get the land measurement certificate(mojan
Last answer on 4/12/2016 2:49:57 PM. by S L Gupta (Civil Engg). Forum started by shashikantc
2154
helloI wanted to know how much should I be charging for a client who just wants
Last answer on 8/9/2013 10:02:39 PM. by Purvi Panchal. Forum started by sruti
2028
BDA plot in bangalore
Last answer on 2/4/2014 11:07:24 AM. by S L Gupta (Civil Engg). Forum started by Vittal
2284
5497
Triangular gaumukh and shermukh plot house plans
Last answer on 6/21/2016 1:00:40 AM. by Beenu Phogat. Forum started by Shaurya Rana
2116
READY MIX PLASTER
3784
Orientation of Building
Last answer on 8/6/2010 2:09:05 PM. by narayan. Forum started by pooja
2717
Wall Bed
Last answer on 9/14/2010 5:14:09 PM. Forum started by sandeep
3058
What are the basic things that are needed while painting?
Last answer on 10/8/2010 11:47:06 AM. by Sazid Ali. Forum started by Sazid Ali
2748
2647
procedure of building layout detail
Last answer on 3/15/2011 6:11:55 PM. by Mohini Sharma. Forum started by kanwer sajjad
2323
Pls what are the procedures in doing this floor
Last answer on 5/23/2012 12:44:44 PM. by S L Gupta (Civil Engg). Forum started by lilian
cost of construction of type G + 2
Last answer on 8/26/2012 4:08:55 PM. Forum started by santhosh
2199
cost estimation is on today's Date.
Last answer on 6/1/2015 11:35:08 AM. by S L Gupta (Civil Engg). Forum started by manish
1705
marriage function hall
Last answer on 11/3/2016 10:46:33 AM. by S L Gupta (Civil Engg). Forum started by swapna
1831
I am interested in one of thhe root decoratoin, wanted to know details like cont
Last answer on 5/16/2015 7:47:24 PM. by JAI PRAKASH. Forum started by sajjunaqvi
1708
I wanted to know who specializes in customized countertops that are may be cut o
Last answer on 1/15/2011 5:04:28 PM. Forum started by khalidmarkar
2399
2966
8093
software
3884
2719
1821
lanterns
3113
false ceiling
2228
about construction
1769
4140
Cement Coba
3060
Water Harvesting System
1650
1737
water tank
2043
1746
1622
Pool construction cost
1970
2720
Regarding roof beam
2045
Fire Stair case
2630
2355
super structure
Lets Know More About WOOD
Lets Know More About WOOD The beauty of wood is that is often linked with memories-the old wooden jhoola in a holiday
Water for Construction
