Layout and House Plans
Fri Mar 04, 2016
santosh
Topic: i want to make foundation for 20x15' so what should be the foundation size is it
i want to make foundation for 20x15' so what should be the foundation size is it 28x23 or any other size
The comment above talks about the image below.
Click on
the image to enlarge.
Fri Mar 04, 2016
Dear Santosh
The foundation design is done with load and bearing capacity of soil. Keep the depth at least 3' from natural ground or up to hard strata. Width of concrete should be from 30'' to 36'' and masonry should be from 23'' to 27''
Sat Mar 05, 2016
That's correct.
Layout and House Plans-Construction Questions (38)
2943
Need suggestions
Last answer on 2/28/2014 8:14:45 PM. by
viju
viju
1050
Last answer on 1/25/2021 8:28:32 AM. by
Sonu Adak
3282
My plot is 5 feet below the road level. Will fill it up with sand after the foun
Last answer on 4/25/2018 1:12:52 AM. by
RAJAT BANGA
2681
Last answer on 8/16/2016 11:39:31 AM. by
freekundli
MASTHAN
2806
building a house
nashir
2494
Help regaring foundation
Last answer on 4/16/2014 3:46:11 PM. by
SANKARDAS BANERJEE
vaisakh
4728
tie beam obsolete
Last answer on 7/3/2020 11:09:31 PM. by
AD
2056
Last answer on 4/6/2016 11:43:24 AM. by
zakia sultana
1691
material requirememt question
Last answer on 12/26/2015 7:41:53 PM. by
sushantsah
2483
Pile Foundation
Last answer on 8/29/2013 11:42:42 AM. by
Arun
2403
Last answer on 1/29/2022 8:02:25 AM. by
shailesh yadav
Last answer on 11/18/2013 10:57:21 AM. by
adari haripraveen
1906
Last answer on 11/18/2013 10:38:53 AM. by
adari haripraveen
6500
Last answer on 1/10/2021 3:19:31 AM. by
bharat patel
2307
Last answer on 4/13/2011 6:59:26 AM. by
rammohandas
4235
Last answer on 7/3/2020 9:21:21 PM. by
H S Rathi
rajeev
4931
Last answer on 6/24/2021 1:12:48 PM. by
sunny420
3857
Last answer on 9/22/2021 6:50:36 AM. by
Hi sir,I have already make a foundation so I need
Last answer on 7/3/2020 10:30:07 PM. Forum started by
Malik
2671
Raj
2173
Amutha
2165
vanramr
2762
raghu
4492
Nitien Parmar
suryarao p
2268
Deepak Giri
2239
ajay sharma
2745
u v sudhakar
3445
ramana
2342
srinivas kamsali
1945
tanaya483
2200
ramanapeddu
3579
SRIKANTH.S
2307
HIRA SINGH
2778
Alexander Graf
Mohiuddin
1535
uma shankar
2106
mohammedbasha
Designing a Foundation
