Thu Aug 21, 2014Total posts : 2
ADINATH
ADINATH
Topic: ideas to reduce heat from terrace roof
dear members ....I am facing a huge problem because of the heat from our exposed flat terrace....the room boils like an oven in summer and the heat is so unbearable that it is difficult to even stay in the house...now I am planning to build a first floor with sloping terrace but am worried that I will face the same proble in the upstairs rooms...
I have learnt that using clay roof tiles on top of the rcc terrace keeping a gap between the two helps reduce heating problem.
can anyone confirm that this arrangement actually works ?
Fri Aug 22, 2014Post  #1
        for this problem do thermal insulation
Thermal insulation is a method to reduce the transfer of heat from outside to inside. To make house heat proof, thermal insulation is a good choice. An insulated home is more comfortable as the temperature remains consistent over weather changes. It makes the house comfortable and keeps the temperature of   house cool in summers and warm in winters. It is very useful to keep the temperature of the house independent from outside temperature.See link below
http://www.gharexpert.com/articles/Finishing-1607/Thermal-Insulation-Home_0.aspx
Sat Aug 23, 2014Post  #2
ADINATH
ADINATH
thank you sir ! very helpful information.
2399
what kind of roof heat resistent
Last answer on 2/11/2011 1:28:43 AM. by Nikita. Forum started by arun
2530
Reasons of dampness
2068
Can anyone pls.advice me regarding exterior tiles which will reduce heat inside
Last answer on 9/26/2010 5:41:32 PM. by S L Gupta (Civil Engg). Forum started by seema nair
2203
my house is on ist floor,but it gets too much heated due to terrace , what to do
Last answer on 10/2/2009 10:44:20 PM. by Priti Arora. Forum started by salim noorani
2114
I m constructing my house in DURGAPUR (W.B.).WOULD LIKE SOMEONE TO HELP ME FOR S
Last answer on 12/7/2010 10:00:13 AM. by S L Gupta (Civil Engg). Forum started by SHEKHAR
1981
Lights, Design & Action
Last answer on 6/15/2010 2:29:45 PM. by RAFAHMED. Forum started by ipiyali
2138
Roof insulation
Last answer on 9/20/2014 12:13:54 PM. by S L Gupta (Civil Engg). Forum started by sb
roofing on open terrace
2302
Terrace water proofing
5170
2095
heat proofing the roof while contruction
Last answer on 9/17/2013 11:04:47 AM. by S L Gupta (Civil Engg). Forum started by vinayvaid
2371
want to make permanent rcc/ tiles on my roof.let me know the way to heat proof
Last answer on 9/17/2013 11:01:50 AM. by S L Gupta (Civil Engg). Forum started by vinayvaid
1981
Underfloor Heating - Home Heating Equipments
Last answer on 6/16/2015 4:05:32 AM. by JAI PRAKASH. Forum started by kevinlee
1774
ROOFING
Last answer on 4/15/2015 9:28:05 AM. by mohit. Forum started by mohit
2080
Daylighting
Last answer on 12/31/2020 1:23:49 AM. by Gunjan Utraja. Forum started by prakash vankani
1823
Which color tiles good for Heat
Last answer on 1/10/2016 8:51:34 PM. by JAI PRAKASH. Forum started by venkatesh
1596
1785
Roof Garden
Cooper
Asphalt
Asphalt Shingles Roofing
