Wed Jun 25, 2014 | Post #1 | S L Gupta (Civil Engg)
Vinyl flooring is generally used to ornament floor
in residential and non residential buildings. Vinyl flooring is
laminated, solid resilient, unbreakable and flexible having non porous
surface. This flooring is resistant to mild or diluted acids, alkalis,
soaps, detergents and petrol. It is high wear resistant and can be
cleaned easily with wet cloth. If it is cleaned immediately,
concentrated acids and alkalis have no effect on the surface of floor.
Do not throw burning cigarette butts or match sticks on floors. To avoid
scratches on the surface of floor, do not drag any heavy object or
furniture on floor.
Constituents of Vinyl FlooringVinyl flooring consists
of thermoplastic binder, filler and pigments. The thermoplastic binder
should consist substantially of one or both of
• Vinyl chloride polymer • Vinyl chloride copolymer
Vinyl flooring material should confirm to IS Number (IS: 3462).This
floor material is available in various thicknesses i.e. 1.5 mm, 2 mm,
2.5 mm, 3mm and 4 mm. It is available in shape of tiles or roles having a
length from one meter to ten meters.
Adhesive for Vinyl Flooring
Rubber based adhesives are used to fix PVC flooring over concrete,
wooden and metal sub base flooring. PVA based adhesives should be used
for concrete and wooden sub floors but they are not good for metal base
and on damp floors.
How to prepare sub base for vinyl flooring?
Step 1: Prepare hard, dry and damp proof baseSub
base should be hard, dry and damp proof. If vinyl flooring is laid on
damp base, moisture slowly damages adhesive resulting in separation and
curling of PVC sheet from the base. Vinyl flooring can be laid on any
sub base such as concrete floor, wooden floor.
Step 2: Lay damp proof base concrete in two layersAt
ground floor, the base concrete should be laid in two layers with damp
proof layer including damp proofing on walls at least up to 6 inches
from floor level. In case of new work, it should be left for at least
one month for drying.
How to install vinyl flooring?
Step 1: Clean sub base of all dustSub
base for vinyl flooring should be cleaned of dust. It should be dry.
The surface of sub base should be free from grease and grit.
Step 2: Set the temperature between 20 to 30 degrees centigradeBefore you lay flooring, materials should be stored at room temperature at for 24 hours. During
installation the temperature should neither fall below 20 degree
centigrade nor shall exceed 30 degree centigrade and at least for 48
hours.
Step 3: Use adhesives on sub base for proper fixingVinyl
flooring should be first laid for trial without using adhesive
according to required layout. Then the adhesive should be applied on sub
base and backside of PVC sheet for proper fixing. Usually after half an
hour when adhesive is sticky to touch, the PVC sheet should be pressed
on the sub base. Then the sheet should be pressed using a roller
weighing about 5 kg to develop proper bond with sub floor.
Step 4: Do installation in dry conditionsMake
sure that there is no air between the sheet and back ground surface.
Avoid floor installation under high humidity conditions.
Step 5: Check alignment and clean top surfaceAfter
laying each row the alignment should be checked. Also make sure that
there are minimum joints between two rolls/tiles. After completing the
work, the top surface should be cleaned thoroughly by using wet cloth
and solvent.
Note : After installations, do not use flooring at
least for 24 hours. Metallic edge strips should be used to protect edges
of flooring.
Benefits of blended vinyl flooring
- Versatility
- High durability
- Low maintenance
- Easy to install and clean
- No need to hire a professional for installation
Drawback of blended vinyl flooring
It can be cut, scratched, burnt and bent easily.
Questions (39) | |
3807 views | 1 answers | Last answer on 7/3/2020 9:51:48 PM. by Karan. Forum started by v d nagar | 2317 views | 2 answers | Last answer on 7/3/2020 11:34:52 PM. by JAI PRAKASH. Forum started by RIYAJ KHAN | 2355 views | 2 answers | Last answer on 2/22/2022 11:43:56 PM. by Vaasku. Forum started by manish singhvi |
| 1597 views | 1 answers | Last answer on 7/3/2020 11:26:58 PM. by S L Gupta (Civil Engg). Forum started by Yousuf | 3382 views | 1 answers | Last answer on 8/27/2020 1:21:14 AM. by S L Gupta (Civil Engg). Forum started by nitinn gupta | 2569 views | 4 answers | Last answer on 7/3/2020 11:34:39 PM. by S L Gupta (Civil Engg). Forum started by mohinder singh | 2052 views | 2 answers | Last answer on 10/7/2014 11:40:52 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE | 1943 views | 0 answers | Last answer on 12/21/2010 6:14:04 PM. Forum started by Vanshri | 3113 views | 3 answers | Last answer on 7/3/2020 11:32:44 PM. by Gunjan Utraja. Forum started by pumping iron | 1921 views | 0 answers | Last answer on 7/9/2011 11:07:07 PM. Forum started by Kehinde Taiwo | 2300 views | 1 answers | Last answer on 7/3/2020 11:35:07 PM. by JAI PRAKASH. Forum started by ashok | 1771 views | 1 answers | Last answer on 12/31/2016 1:13:43 PM. by S L Gupta (Civil Engg). Forum started by amit | 1612 views | 0 answers | Last answer on 10/4/2016 9:21:30 PM. Forum started by Kamrul | 3351 views | 1 answers | Last answer on 7/3/2020 11:34:27 PM. by Nikita. Forum started by dr.bharadwaj | 2104 views | 3 answers | Last answer on 10/21/2010 8:22:02 PM. by priya. Forum started by Andrew Virgil | 1407 views | 1 answers | Last answer on 6/1/2016 11:29:05 AM. by S L Gupta (Civil Engg). Forum started by Nations Construction | 1669 views | 1 answers | Last answer on 1/5/2022 12:58:42 AM. by S L Gupta (Civil Engg). Forum started by Yousuf | 4718 views | 5 answers | Last answer on 7/3/2020 10:22:17 PM. by sam. Forum started by kedar das deogam | 0 views | 0 answers | Last answer on 8/6/2011 2:49:12 PM. Forum started by shabbir ali | 10 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 9 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
Articles that might interest you! | | What are the important steps of maintenance after installation of blended marble vinyl flooring? Important steps of maintenance after installation of blended marble vinyl flooring......... | | Tips for maintaining Flooring Proper maintenance of flooring is required to retain the beauty of floors and home as well. The flooring preserved nicel | | Vinyl Flooring Are you looking for unbreakable, flexible and non porous flooring? Vinyl flooring or PVC flooring is the best choice. .. | | Which place is suitable for installation of blended marble vinyl flooring? Suitable places for Blended vinyl flooring---Rooms......... | | How to Install a Sink Installation of kitchen sink requires just few tools,material and a beautiful sink according to your needs. Read the s.. | | What are the various ways of the Installation of Vinyl flooring? Vinyl flooring can be installed as either sheet or tile.................. | | Lawn Care Tips Timely care and proper maintenance are essential to preserve the beauty of lawn. If you want to enjoy prettiness of na.. | | Italian Marble Flooring Italian marble is a wonderful material that can quite simply enhance the beauty and elegance of any room. However, whe.. | | Specifications of marble stone flooring Marble stone is one of the common and best components for flooring. Use of marble provides a shining and impressive lo.. | | Hardwood Flooring and its Installation Hardwood flooring is one of the expensive yet elegent flooring option. Its installation is not that typical but still .. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
