Home -> Forums -> Construction -> Basement -> in concrete piller using more cement sand than20 mm jelly what is the result will be?
Tue May 19, 2015Total posts : 1
manja nayka k r
manja nayka k r
Topic: in concrete piller using more cement sand than20 mm jelly what is the result will be?
Hi. Sir
iam constructing house my mestri is using more sand than jelly in pillar column what will be the effect sir please tell me
Tue May 19, 2015Post  #1
Cement Concrete 1:2:4:-
                                           Where cement concrete 1:2; 4 ratio is used it means 1 part cement 2 parts of fine aggregate or coarse sand and 4 parts of coarse aggregate. This ratio cement concrete has good strength and is recommended for the following type of buildings and works:-
• Used in footings of columns and raft foundation, used in beams, slabs, columns, stairs and walls of ordinary, single story and temporary buildings and used in retaining walls, pavements, floors and bedplates etc.
1766
1460
32559
Cost of RCC Pillar
3949
Cost of construction of RCC Piller with Foundation
Last answer on 4/22/2014 11:15:43 AM. by S L Gupta (Civil Engg). Forum started by Subhajit Kundu
8651
2679
3039
use of tmt bar
3272
For Estimate
2063
cement : sand:stone ratio
3591
3030
3589
Per Sq:ft rate for flooring
3791
3842
2242
sand alternate for concrete
6450
2910
2421
start construction Steel use
2276
9061
makan map
2774
17223
1993
2157
design of column
2281
2252
Underground water tank
2657
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
2797
1970
ffff
1872
4211
Selection of cement ..
3465
2016
Regarding construction
3154
Basement Water proffing
2015
Acid staining
Hard
Using
Skylight
Concrete Decor
Types of Cement
