Home -> Forums -> Construction -> Start Construction -> increase the height of plinth area
Wed May 01, 2013Total posts : 3
randhir
randhir
Topic: increase the height of plinth area
I have a house which was made in 1995. It is along the road side.
Now the situation is that the plinth area has gone down in comparison of road approx. 1/2 mtr.
Is there any solution for increasing the height of house or plinth.
Pls suggest. i will be obliged for this.
Thu May 02, 2013Post  #1
Dear Randhir
        If height of roof is 12' or 13' than you will raise the floor of the house. Secondly if height of roof is less than contact the agency which lift the roof slab by applying pressure on JACK. In this system they lift the roof than you will have to raise the chowkats and floor.
Thu May 02, 2013Post  #2
randhir
randhir
Post subject: height of plinth area
Heartly thanks for the reply.
Do u have any address for the agency who lift the roof slab by applying pressure on jack?
Secondly can u suggest me that approx. how much cost will be incurred for the above.
Randhir
Fri May 03, 2013Post  #3
Dear Randhir
        There are so many agency in every city. Try to contact cement vender or other raw material supplier who have contact with labor and labor related agency.Cost will differ from city to city and according to nature of work.
2263
roof centering polls
Last answer on 2/4/2013 11:37:01 AM. by atlantaroofingcont. Forum started by ringwang
1890
What will be cost increse for every foot increase in height of ceiling ?
Last answer on 2/22/2013 11:42:44 AM. by S L Gupta (Civil Engg). Forum started by s.m.sudhan
4911
How much it cost for laying a foundation for a 30x40 site upto 7ft deep and plin
Last answer on 5/4/2013 2:20:44 PM. by nithun. Forum started by nithun
2243
Is plinth area and builtup area are same?
Last answer on 9/21/2016 12:10:11 AM. by Pawan kumawat. Forum started by hariprasad
2085
Last answer on 1/8/2018 11:06:10 PM. by S L Gupta (Civil Engg). Forum started by ravikumar
22203
Difference between plot size area, built-up area, plinth area
Last answer on 3/17/2016 12:21:27 PM. by S L Gupta (Civil Engg). Forum started by vamsi
5818
Industrial shed construction
Last answer on 1/8/2022 4:18:30 AM. by S L Gupta (Civil Engg). Forum started by shikha Chetal
2501
Approx.cost of construction from plinth area to completion of plastering for a12
Last answer on 12/23/2013 12:45:58 PM. by S L Gupta (Civil Engg). Forum started by neelam rathi
3840
Give some proof that we have to use plinth area when both plinth area and plot area is given.
Last answer on 8/14/2014 8:23:37 AM. Forum started by vishal kumar
Give some proofs that we have to use plinth area to make plan if we have both plinth area and plot area
Last answer on 8/14/2014 8:28:46 AM. Forum started by vishal kumar
3388
Square 4 side Pyramid Frame by MS Steel for RCC.
Last answer on 7/29/2014 2:33:14 PM. by S L Gupta (Civil Engg). Forum started by Shailendra Singh
9213
PROCEDURE FOR MEASURE PLINTH HEIGHT
Last answer on 7/3/2020 11:32:36 PM. by S L Gupta (Civil Engg). Forum started by SUNIL
1717
Is there a rule such as a ratio of Plinth area to saleable area that is mandated
Last answer on 1/26/2021 10:31:37 PM. by S L Gupta (Civil Engg). Forum started by joseph
2874
Column Size and distance
2635
Roofing elevation
Last answer on 12/24/2014 4:28:01 PM. by S L Gupta (Civil Engg). Forum started by Sai Pavana
3144
Plinth beam at ground level
3888
6270
Plinth Area Rate per SQ.m of Building
Last answer on 9/8/2015 9:31:21 PM. by JAI PRAKASH. Forum started by pratham158
2485
3312
3323
4454
4029
2253
2729
4239
5215
2398
2324
2027
2466
2145
3218
2078
12549
2194
2036
2758
Rugs
Rugs for Living Room
What affects the life of doors? What can we do to increase the life of the Aluminium doors?
Tips to increase the life of Aluminium doors....
Utilization
How to Increase productivity in office
A comfortable and well designed office may increase the productivity of employees. Office space design requires imagin..
Fountain Types
