Home -> Forums -> Construction -> Start Construction -> is it better to construct slab before brick work in walls?
Thu Jul 26, 2012Total posts : 1
sanjay kumar makhija
Topic: is it better to construct slab before brick work in walls?
is it better to construct a slab before a brick work becausepeople here constuct brick wall before slab?
Thu Jul 26, 2012Post  #1
Dear Kumar
There are two typs of construction, One is with load bearing walls and other is frame structure building i.e. load is to be bear by columns.
In case of loadbearing walls we have to costruct the wall first than lay the RCC slab.
In frame structure building we can make wall either before laying the slab or after laying the slab.
11829
cost of rbc and rcc slab
2150
Sunken slab
Last answer on 1/17/2021 5:51:16 AM. by freekundli. Forum started by Bhaskara
3457
2866
Bricks
3992
2018
2331
i am constructed the circular wall of 30 feet dia.,30 feet height
Last answer on 1/6/2022 10:11:07 AM. by S L Gupta (Civil Engg). Forum started by shivprasad
2590
RCC SLAB
Last answer on 7/4/2020 2:15:20 AM. by S L Gupta (Civil Engg). Forum started by nagendrabk
3626
chair in slab steel
Last answer on 4/23/2014 8:34:50 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
3087
3470
Cost of concrete walls
2836
Compound Wall Construction
13651
3669
wals
9196
2198
Usage of M-Sand in Bangalore
9555
Last answer on 10/17/2016 1:19:41 PM. by Vishal Thakur. Forum started by Vishal Thakur
3312
2236
2312
2061
Brick Arches
