it is enough to build 4 to 8 feet for kitchen
Mon Dec 24, 2012Total posts : 2
jayalakshmi
jayalakshmi
Topic: it is enough to build 4 to 8 feet for kitchen
Tue Jan 01, 2013Post  #1
Pavan
Pavan
Post subject: Kitchen
Hello Jaya,
See tio that you are comfortable enough to stand and work in the Kitchen. Also Ensure enough ventilation in this Kitchen. Kitchen is the source of healthy leaving.
Try to keep the kitchen neat and clean, If it is possible to have this kitchen with a window in the east, In that case you will get a enough source of UV ray of Sun that helps a ton.
Thanks & Regards
Pavan Matkar
Mon Feb 11, 2013Post  #2
akmurty1
akmurty1
Post subject: kitchen size
minimum size is 6 x 8 feet
Hi Now I am in the construction, my kitchen is 10 feet x 10 feet, your expert is
Last answer on 8/1/2018 11:35:24 PM. by S L Gupta (Civil Engg). Forum started by kannaa
1968
i wish to build a kitchen in 4 to 8 feet
Last answer on 12/25/2012 5:24:11 PM. by S L Gupta (Civil Engg). Forum started by jayalakshmi
3426
1840
How to plan steel dimention for load bearing pillars
Last answer on 8/5/2015 4:41:11 AM. by JAI PRAKASH. Forum started by Joshy
2878
1538
2331
i am constructed the circular wall of 30 feet dia.,30 feet height
Last answer on 1/6/2022 10:11:07 AM. by S L Gupta (Civil Engg). Forum started by shivprasad
1692
Query if the plot size is good for constryuction
Last answer on 3/5/2016 10:34:16 PM. by JAI PRAKASH. Forum started by NIRMAL
2196
1570
1671
How many sq feet marble needed in 1700 sq feet area with kitchen and two floor stairs.
Last answer on 7/12/2016 10:45:15 AM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
1601
Last answer on 10/18/2016 5:17:56 PM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
2501
2176
New column footage and pillar very next to the wall of existing building
Last answer on 10/30/2014 5:27:13 PM. by Rachael Suggs. Forum started by Robert
3502
3510
2943
RCC Roof SPAN
Last answer on 5/29/2013 10:29:12 AM. by S L Gupta (Civil Engg). Forum started by Rajesh
2443
Am living in a rented house,where the kitchen is on south east
Last answer on 11/29/2014 2:46:08 PM. by seema tyagi. Forum started by Niyaz
24
28
Designing
Designing a Foundation
Orientation
Orientation of Building
Kitchen Accessories
Kitchen Remodeling Ideas
Kitchen Backsplash
Kitchen Cabinets
Small
Small Space Kitchen
