Thu May 10, 2018Total posts : 3
RAJAT BANGA
RAJAT BANGA
Topic: Is it fine to have overlap in steel bars just before the roof ?
Fri May 11, 2018Post  #1
RAJAT BANGA
RAJAT BANGA
Request the experts to help me in the above mentioned query. I am an individual and getting my own house constructed. Have no background to civil engineering.
Please reply soon. Thanks
Wed May 16, 2018Post  #2
      There should be no joints in steel bars used for RCC work. If it is necessary to use small length steel bars, proper overlap should be given.
The joints of bars should be welded in case the diameter of bars is more than 36 mm. Overlapping of bars should not touch each other and they should be kept apart. Where it is not possible, overlapping bars should be bound together at intervals not exceeding twice the diameter of such bars with two strands of steel wires trusted tight. The overlap should be staggered for different bars. The length of overlap should not be less than 50 times the diameter of steel bar.
Mon May 21, 2018Post  #3
VivekC
VivekC
Overlapping must be avoided at all costs especially when RCC is involved.
overlap length to steel
15582
2898
RCC Roof
13755
1695
Roof related
Last answer on 3/5/2016 10:32:12 PM. by JAI PRAKASH. Forum started by Pooja
4647
1632
3059
steel formula
Last answer on 4/16/2014 8:05:15 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
3753
3510
3626
chair in slab steel
Last answer on 4/23/2014 8:34:50 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
2248
3108
2036
2707
2302
2033
1272
Type
HSD
TMT
Steel
Steel Roofing
Precautions
