Is it true that having water tank at southwest coner helps in collecting money?
Sat Sep 11, 2010Total posts : 1
punam
punam
Topic: Is it true that having water tank at southwest coner helps in collecting money?
Is it true that having water tank at southwest coner helps in collecting money? please guide me.
Mon Sep 13, 2010Post  #1
Post subject: Water Tank in SW
Having an underground water tank in SW is not good for male health and progress. However to add weight and height in the SW corner an overhead tank can be built.
Sabina Vanjani-Vastu Analyst
5069
6280
Water Tank Quality
2926
Last answer on 4/11/2017 11:10:57 AM. by S L Gupta (Civil Engg). Forum started by vinu
2207
My house is under construction kindly advice the position of septic tank.Option
Last answer on 9/7/2010 5:46:10 PM. by sabina vanjani. Forum started by piyu sur
3086
Water Harvesting System
3130
2495
1740
1941
2191
2384
water tank
1854
7244
2 lakh litre water tank
3000
Basement Interior Design
Last answer on 11/26/2010 2:58:05 PM. by S.C.Chawla. Forum started by Boby
1891
water tank motor capacity
2392
5171
2244
Love Vashikaran Specialist Astrologer in Nashik 91-9056562757
Last answer on 1/6/2025 3:03:02 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:03:01 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:03:00 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:59 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:57 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:56 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:55 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:53 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:52 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:51 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:50 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:49 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:48 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:47 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:46 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:45 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:44 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:43 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:41 AM. Forum started by Pandit Sahil Sharma Ji
Vastu for Water Tank
Preventive
Reasons of dampness
Cement Concrete Raw Material
Read points should be kept in mind while collecting raw materials for cement concrete in construction work.
60
60 Tips to Save Water
