Home -> Forums -> Construction -> Start Construction -> What are the item excluded if i choose only labour contract.
Fri May 24, 2013Total posts : 0
ananth
ananth
Topic: What are the item excluded if i choose only labour contract.
Dear All,
What are the items(work) excluded if i choose only labour contract(with all in all) without material. Like (worker's house near by building construntion area, other supporting materials used while doing like cetring..ect).
What are the points i need to discuss with contractor before make an aggreement? (With out material by them).
I have building approval from CMDA (Chennai). I need to start work soon.
Please give me idea on this.
Thanks,
Ananth
2602
Anyone having payment terms for labour contract for house
Last answer on 12/15/2015 12:57:03 PM. by S L Gupta (Civil Engg). Forum started by sushantsah
2283
2426
Labour only or Labour+Material contracor
Last answer on 7/16/2013 11:00:12 AM. by S L Gupta (Civil Engg). Forum started by Harsh
2770
Last answer on 7/12/2018 5:49:08 PM. by S L Gupta (Civil Engg). Forum started by Hameed
2411
labour
Last answer on 5/14/2013 3:14:12 PM. by Kilyen Rampton. Forum started by dan
2004
What is the cost difference between material labour contract and only a labour c
Last answer on 6/26/2013 4:09:27 PM. by Navneet Jharia. Forum started by nithun
cost for completion
Last answer on 10/19/2014 3:40:13 PM. Forum started by jithin
2877
Labour rate
Last answer on 7/4/2020 2:47:30 AM. by S L Gupta (Civil Engg). Forum started by M Prabhu
1255
1670
Last answer on 5/3/2016 12:13:14 AM. by JAI PRAKASH. Forum started by sayeedmohsin
1809
what re these in gharexpert estimates
Last answer on 12/17/2015 2:57:41 PM. by JAI PRAKASH. Forum started by sushantsah
2241
what are the rates of labour contract for making bunglow of 4000 sq ft on column
Last answer on 9/11/2012 9:27:30 PM. by sureshkhot. Forum started by narsi vekeriya
3254
Which area measurement in plan is used by contractor to calculate labor contract rate?
Last answer on 5/22/2021 1:49:37 PM. by S L Gupta (Civil Engg). Forum started by vinu
3425
3697
about size of chowkets
1861
Sir,as i am in final year we have to make major project.so i want to know 3-4 to
Last answer on 10/10/2013 4:01:05 PM. by S L Gupta (Civil Engg). Forum started by shailesh yadav
2383
cost of construction in hyderabad for 80 sq yd
Last answer on 10/27/2015 11:21:28 AM. by S L Gupta (Civil Engg). Forum started by vijaymavarapu
1314
Economical and reliable choice of type of exterior staircase to the rented 1st floor of house.
Last answer on 12/26/2016 1:12:50 PM. by S L Gupta (Civil Engg). Forum started by vinu
2242
Constructing on my own without a Contractor
Last answer on 1/2/2013 10:20:53 PM. by gnyoganarasimhan. Forum started by Vishwanath
3310
