joinery work
Tue Apr 26, 2011Total posts : 1
suresh
suresh
Topic: joinery work
I am constructing my house at jodhpur. i want to know about latest type of door frames, door shutters and windows other than wooden which are cheaper also
Tue Apr 26, 2011Post  #1
Dear Suresh
      For cheaper door frame you can use either pressed steel frame or angle iron frame. Angle iron frame is the cheapest. In window you can use also use section as F7, F4 for frame & shutter.
JOINERY WORKS
2088
joinery work
Last answer on 4/26/2011 9:58:00 PM. Forum started by suresh
3676
cost of plumbing,sanitaion,electrical as %of civil work
Last answer on 11/16/2021 12:22:16 PM. by muralibgowda. Forum started by naina
3376
Bathroom Cleaning Tips
1811
3093
Last answer on 10/5/2020 10:59:59 PM. by S L Gupta (Civil Engg). Forum started by DEVANSU
4426
lobar work quantity
2504
Cement
2764
Plaster work
1749
1654
1813
1776
3637
1839
I'm Working at a govt. approved Project
Last answer on 1/7/2011 6:57:12 PM. by S L Gupta (Civil Engg). Forum started by sanjeev pradhan
1826
it is as if a god work.
Last answer on 9/11/2010 3:39:57 PM. Forum started by antoine vencatasawmy
4235
1859
home panting work part of 30 years expart.ple cal me 9239293464
Last answer on 3/31/2011 11:51:03 AM. Forum started by sankarkarmakar
193
62
23
21
22
22
23
21
21
23
21
21
17
23
18
22
23
Checklist
Checklist for Painting Work
Surface
Preliminary
Wrought
Wrought Iron Furniture
Wrought iron furniture is perfect blend of art and beauty. It’s one of the most popular choices of service providers a..
