Home -> Forums -> Interior -> Kitchen Cooking Range -> kitchen range
kitchen range
Tue Sep 09, 2014Total posts : 1
anjali
anjali
Topic: kitchen range
can someone provide expert opinion that i should install kitchen range or not. Is oven in kitchen range useful ? What are the limitations of kitchen range ?
Tue Sep 09, 2014Post  #1
Yes you can install it.
The oven would be useful.
Limitations:
Cookware must be compatible with induction heating; glass and ceramics are unusable, as are solid copper or solid aluminum cookware for most models of cooker. Cookware must have a flat bottom since the magnetic field drops rapidly with distance from the surface. (Special and costly wok-shaped units are available for use with round-bottom woks.) Induction disks are metal plates—much like a skillet with no sides—that heat up non-ferrous pots by contact, but these sacrifice much of the power and efficiency of direct use of induction in a compatible cooking vessel. Further, cheap induction cookers regulate the transmitted power by simply powering the field on and off for specified times, like most microwave ovens do. If a pot with a thin bottom is used, the contained liquid boils intermittently. This does not occur with cookware that has a thicker bottom or with better induction cookers.
Manufacturers advise consumers that the glass ceramic top can be damaged by impact, although cooking surfaces are required to meet minimal product safety standards for impact.[3] Aluminum foil can melt onto the top and cause permanent damage or cracking of the top. Damage by impact also relates to sliding pans across the cooking surface, which users are advised against. As with other electric ceramic cooking surfaces there may be a maximum pan size allowed by the manufacturer.
A small amount of noise is generated by an internal cooling fan. Audible noise (a hum or buzz) may be produced by cookware exposed to high magnetic fields, especially at high power if the cookware has loose parts; better-grade cookware with welded-in cladding layers and solid riveting should not produce this type of noise. Some users may detect a whistle or whine sound from the cookware, or from the power electronic devices. Some cooking techniques available when cooking over a flame are not applicable. Persons with implanted cardiac pacemakers or other electronic medical implants are usually instructed to avoid sources of magnetic fields; the medical literature seems to suggest that proximity to induction cooking surfaces is safe, but they should always check first with their cardiologists.[4] Radio receivers near the unit may pick up some electromagnetic interference.
An induction (or any electric) stove will not operate during a power outage. Older gas-stoves do not need electric power to operate; however, modern gas-stoves with electrical ignition require an external ignition source (e.g. matches) during power outages.
Kitchen Cooking Range-Interior Questions (28)
3482
I want idea's on setting up an 8ft x 9ft kitchen, with space for a cooking rang
Last answer on 4/20/2012 8:23:15 PM. by S L Gupta (Civil Engg). Forum started by Prudence
2383
can any one tell me the price range of granites in bangalore
Last answer on 7/18/2012 12:55:23 PM. by S L Gupta (Civil Engg). Forum started by padmaraju
2181
Comparing uPVC Windows with Wooden Windows and Aluminium Windows
Last answer on 9/11/2010 11:27:22 PM. by sachin. Forum started by Mahendra Agarwal
2328
2281
which marble and its sub category to buy
Last answer on 7/3/2020 11:36:27 PM. by JAI PRAKASH. Forum started by sushantsah
2004
can u suggest some flooring options for bedroom in the price range of 200-250 pe
Last answer on 7/18/2012 12:04:18 PM. by Ahsan Ali Junaid. Forum started by padmaraju
2415
Cooking Range
Last answer on 10/18/2021 1:09:25 AM. by Gunjan Utraja. Forum started by sarita.angadi
2746
2246
1870
Hi everyone,I have a doubt regarding the leading modular kitchen manufacturers a
Last answer on 3/5/2013 5:09:12 PM. Forum started by Vaithi
3029
I have a Kitchen of 6'' * 10"" Plx suggest some kitchen designs
Last answer on 7/3/2020 10:48:15 PM. by Nisha Batra. Forum started by Sarbani Biswas
3428
Kitchen Island
Last answer on 1/5/2022 2:57:02 AM. by Mike Stanley. Forum started by tiwari_p_k
2766
What are the impacts if the chef is facing South West (SW) while cooking? House
Last answer on 1/20/2021 8:24:42 AM. by sonigupta. Forum started by ramram
3612
Digital Laminates
Last answer on 7/3/2020 10:22:49 PM. Forum started by raghuam
4184
hi,i have a very small kitchen want to change into a modular kitchen can you sug
Last answer on 10/11/2020 7:17:40 AM. by Amit Hasija. Forum started by Rima_M
2801
Is it neceesary to have many windows and doors in kitchen as I have got only one
Last answer on 7/4/2020 2:44:00 AM. by PR Jawahar. Forum started by veena
3110
my kitchen is of 9 by 10 size. I want L shape modular kitchen with serving count
Last answer on 1/28/2021 10:34:37 PM. Forum started by suman
3739
Hi Now I am in the construction, my kitchen is 10 feet x 10 feet, your expert is
Last answer on 8/1/2018 11:35:24 PM. by S L Gupta (Civil Engg). Forum started by kannaa
8126
Modern Kitchen
Last answer on 2/19/2022 3:13:17 AM. by Gohkadd. Forum started by ankita
4891
Nice design for safety door.
Last answer on 1/22/2022 2:38:55 AM. Forum started by jyoti
2415
Cooking Range
2115
Kitchen hobs and built in oven
Last answer on 7/20/2020 12:33:45 AM. Forum started by Akhil
1786
Chimney
Last answer on 7/15/2020 10:56:32 PM. Forum started by Vishwadeep
2671
Kitchen Appliances
Last answer on 1/27/2013 10:14:53 PM. by kcantony. Forum started by Abhijit Chaudhuri
2621
Good Hob and Chimney for Modular Kitchen..
Last answer on 10/2/2012 5:00:05 PM. by Candy Goff. Forum started by raghuam
2051
kitchen stove top southeast or northeast?
Last answer on 12/10/2011 11:38:19 PM. by Amit Hasija. Forum started by Sarah
1790
Sir i have doubt regarding construction . Definitely we will satisfy with your s
Last answer on 9/3/2011 12:38:31 AM. by vijay. Forum started by damodara naidu
2247
can u say me the opening
Last answer on 3/27/2010 3:51:58 PM. by Ajit Tareeka. Forum started by rahul
Kitchen Ventilation
Proper ventilation in kitchen is essential particularly while cooking the food. If there is no suitable ventilation, t..
Kitchen Appliances
In kitchen, your cooking appliances dictate your life style. A perfect cooking appliance offers you to diminish clutte..
Kitchen Accessories
Kitchen Remodeling Ideas
Kitchen Backsplash
Kitchen Cabinets
Small
Small Space Kitchen
Kitchen Counter Tops Part-1
Kitchen Pantry
Well organized kitchen pantry not only makes your meal time pleasant but creates attractive look in your sweet home al..
How to Install Kitchen Sink?
Installation of kitchen sink seems a daunting task but it is just simple to fix a sink in the kitchen. It can be fitte..
