kota Stone Roofing
Wed Dec 16, 2015Total posts : 7
Anu
Anu
Topic: kota Stone Roofing
Hi All,
I want to Know is kota stone  good option on rcc  roof ?
Anu
Thu Dec 17, 2015Post  #1
Anu
Anu
HI Sanjay ,
I am planning Are you planning kota stone on terrace .
Anu
Thu Dec 17, 2015Post  #2
Dear Anu
       If you planning kota stone roofing with Iron girder or T- iron.
                          OR
    You are planning laying kota stone on RCC roof for terrace finish.Brick Tile Terracing is good over Kota stone flooring at terrace due to unnecessary load to the roof, Joints of Kota stone expand on heat during summer season causes leakage and for making proper slab is difficult in stone.
Thu Dec 17, 2015Post  #3
Anu
Anu
Tanks for your valuable suggestion Mr Gupta.
Can you suggest me more option on rcc roof which are water resistant and weather protector.
thanks
Anu
Thu Dec 17, 2015Post  #4
Not Suggested.
Thu Dec 17, 2015Post  #5
Anu
Anu
Hi Jai Prakash,
Kindly Suggest other option for on RCC roof.
Anu
Fri Dec 18, 2015Post  #6
Dear Anu
      If you are not interested in laying brick tiles on roof and want to lay kota stone than follow the procedure.
Paint the roof with bitumen and stick a polythene sheet on bitumen.
Lay concrete and make proper slope for water drainage.
Than lay kota stone but left 15mm to 25 mm joint in two piece of kota stone and fill the joint with cement and marble chips mix and grind after curing.
In this way joint crack problem not exist.
Thu Dec 24, 2015Post  #7
Go for traditional tiles. Do not install any stone.
For porche area flooring, granite stone is slippery and kota stone prone to flak
Last answer on 7/4/2020 2:41:31 AM. Forum started by Surinder Singh
1702
Last answer on 7/3/2020 11:20:06 PM. by S L Gupta (Civil Engg). Forum started by PCR.Manohar
2485
tandur stone
Last answer on 7/13/2014 11:39:43 PM. by JAI PRAKASH. Forum started by anand
3614
if i fix some labour rate with petty contractor of covered area of building wit
Last answer on 12/29/2010 12:36:10 PM. by S L Gupta (Civil Engg). Forum started by sudhir singh
12307
What are the advantages of Kota stone flooring?
Last answer on 6/27/2010 4:58:24 PM. by Ramen Roy. Forum started by harsh
4089
Kota stone for parking area
Last answer on 10/5/2012 7:42:38 PM. by pallubc2. Forum started by pallubc2
Granite and Marble , Kota stone
Last answer on 2/7/2014 10:55:10 PM. Forum started by Nikhil rao
2996
RATE OF KOTA STONE
Last answer on 12/11/2014 11:55:18 AM. by seema tyagi. Forum started by sanjay
2239
Last answer on 1/4/2022 11:02:33 PM. by S L Gupta (Civil Engg). Forum started by nagaraju kakani
9195
2353
laying of roof
3713
exterior walls
2645
3326
Red stone roofing
Last answer on 5/15/2013 12:46:52 PM. by S L Gupta (Civil Engg). Forum started by SCK
2310
Stone on elevation
Last answer on 9/23/2015 11:38:20 PM. by sanjay agarwal. Forum started by rishabh
1406
sir, what is the costing of tandur stone?
Last answer on 4/2/2017 7:48:45 PM. Forum started by gautam
1814
1905
What kind of red stone it is ,applied in stairs
Last answer on 10/24/2013 11:45:48 AM. by S L Gupta (Civil Engg). Forum started by abhi singh
3397
Bathroom Cleaning Tips
17
Appropriate
Advantages
Colors
Colors of Kota Stone
Kota Stone is a natural stone found in attractive, beautiful and eye soothing natural shades of greenish blue and brow..
Cooper
