Home -> Forums -> Construction -> Start Construction -> labour factor guideline
Mon Aug 08, 2011Total posts : 2
Rajagopal
Rajagopal
Topic: labour factor guideline
I wish to know a guideline of labour payment at foundation, roof, brick work completion and plastering level to avoid excess payment to labour contractor.
Mon Aug 08, 2011Post  #1
Pushp raj
Pushp raj
talk with contractor and decide the payment in sq.ft
Thu Aug 11, 2011Post  #2
Dear Raj
Before starting the work you should make written agreement with the contracor about payment shedule. One patteren is given below.
1. Fix the payment schedule on the pattern given below
a) 20% on collection of raw materials and tools & plant at site.
b) 30% after laying roof slabs.
c) 10 % after cement plastering.
d) 10 % after laying flooring.
e) 10% after fixing door and window shutters.
f) 10 % after fixing sanitary wares, electric fittings and door fittings etc.
g) Remaining 10% after completion of building including painting, “snocem” fixing grills etc. in all respects.
h) Proper receipt of every payment should be taken; if possible payment should be made through cheque.
There are lot of material about construction for knowledge on the web site gharexpert.com, where you can find about construction, vastu, interioretc. For hiring contractor and payment shedule see article link given below.
1675
roofing on open terrace
2602
Anyone having payment terms for labour contract for house
Last answer on 12/15/2015 12:57:03 PM. by S L Gupta (Civil Engg). Forum started by sushantsah
2282
2425
Labour only or Labour+Material contracor
Last answer on 7/16/2013 11:00:12 AM. by S L Gupta (Civil Engg). Forum started by Harsh
2004
What is the cost difference between material labour contract and only a labour c
Last answer on 6/26/2013 4:09:27 PM. by Navneet Jharia. Forum started by nithun
2418
Paint
Last answer on 6/11/2019 1:36:44 AM. by S L Gupta (Civil Engg). Forum started by mahender
2069
structure
Last answer on 4/21/2014 3:03:37 PM. by S L Gupta (Civil Engg). Forum started by HAMEED
2578
how much labour cost of new cnstruction
Last answer on 12/9/2013 1:25:21 PM. by S L Gupta (Civil Engg). Forum started by bharat patel
1833
I want to construt 1200X900x50 mm chamber cover.what will be cost (material and
Last answer on 3/2/2015 11:59:21 AM. by S L Gupta (Civil Engg). Forum started by sachin kale
4231
labour rate
3574
construction current rate
1224
what is the labour out for scaffolding
Last answer on 7/4/2020 4:29:57 AM. by S L Gupta (Civil Engg). Forum started by santosh pore
1368
what is the standard labour outputs for different work in is code
Last answer on 7/4/2020 4:30:08 AM. by S L Gupta (Civil Engg). Forum started by santosh pore
1006
Shuttering and labour cost 1600sft
Last answer on 7/3/2020 11:13:46 PM. by S L Gupta (Civil Engg). Forum started by Sri
2530
Climatology - study climatic factors that can lead to make a Perfect Home
Last answer on 11/26/2021 6:23:17 AM. Forum started by ashish batra
3196
labour cost
2648
3258
3309
2133
2059
