Home -> Forums -> Construction -> Start Construction -> latest price of building materials in bangalore
Sun Oct 10, 2010Total posts : 7
manjuks
manjuks
Topic: latest price of building materials in bangalore
Dear ALL.
I intend to build an independent house on 2nd floor on existing house in H S R Layout, Bangalore.
I want to know the latest prices of civil construction materials like cement, sand,jelly,steel for building construction in bangalore.Can any one send me the latest price list and indicate me the resources/links which gives the tools to calculate the building material required for construction.
from
k s manjunatha
e mail : mnathks@gmail.com
Mon Oct 11, 2010Post  #1
Dear KS Manjunatha
   1. For rate of latest building construction materials, you should contact building material supplier at banglore who are in position to give latest rate of materials.
2. For calculating quantity of materials, you should contact suppot@gharexpert.com. by sending plan of your building you can get detail cost estimate with detail of quantity and tips for construction. For sample of detail estimate you can see the linc below.
Mon Oct 11, 2010Post  #2
 Here is the link of detail estimate.http://www.gharexpert.com/include/sample_estimate.pdf
Tue Oct 12, 2010Post  #3
baskar20
baskar20
Post subject: Marriage Hall Construction Procedure
ssdsdsdDear Sir / Madam,
I am planning to buy a land an construct a marriage hall in Chennai. I would like to know the procedure to be adopted for this.
Kindly let me know what kind of approvals that I need to obtain, any no objection lettrs or so because the land that I am thinking of is in a residential area.. Do I need to convert the residential to commercial purpose zoned land ?
Your help will be highly appreciated.
Thanks,
Baskarn
Tue Oct 19, 2010Post  #4
ardes_architects
ardes_architects
Why are my posts deleted by admin….because I gave an informative reply and make you lose your business?
If there is something wrong in my answers leave an admin note or send a mail. Removing the posts is not professional.
Ar.Praveen.N
Ardes Architects and Interior Designers
Mon Oct 10, 2011Post  #6
S.K.NAGARAJ
S.K.NAGARAJ
Post subject: S.K.NAGARAJ
Dear sir,
i want to build 20square of duplex house, please give me the details how economical i can work and what will be the budget
Wed Jun 06, 2012Post  #7
rudresh
rudresh
Post subject: river sand suuply
Dear all
Im supplyar of sand nd bluematles like 20mm, 40mm, 12mm, in risanble price.
con. no;. 9986463847
11410
WHAT IS TH PRICE OF TEAK WOOD IN BANGALORE
Last answer on 12/28/2011 10:07:52 PM. by S L Gupta (Civil Engg). Forum started by ramesh s
2383
can any one tell me the price range of granites in bangalore
Last answer on 7/18/2012 12:55:23 PM. by S L Gupta (Civil Engg). Forum started by padmaraju
2797
1792
pl.send latest archi.view of building and latest technology of indiestries.Thank
Last answer on 11/15/2011 5:31:00 PM. by Amit Hasija. Forum started by prakash gohel
2558
Bye Law
2336
Last answer on 9/19/2012 1:30:40 PM. by r s rawat. Forum started by mujahedsabb
2771
Last answer on 7/12/2018 5:49:08 PM. by S L Gupta (Civil Engg). Forum started by Hameed
2877
Labour rate
Last answer on 7/4/2020 2:47:30 AM. by S L Gupta (Civil Engg). Forum started by M Prabhu
1913
building material
Last answer on 3/23/2015 10:00:27 PM. by JAI PRAKASH. Forum started by shaheryar
7232
2 lakh litre water tank
2681
i have 600 sq ft plot at nandhi layout bangalore opp to devi temple , between pl
Last answer on 7/30/2014 10:56:32 AM. by S L Gupta (Civil Engg). Forum started by balakrishna
5086
1885
can i get the plans and material list would like to build this
Last answer on 6/18/2012 3:25:01 AM. by Gunjan Utraja. Forum started by Jeremy
2258
I am planning to build a house in bangalore . Do anyone know good contractors wh
Last answer on 2/11/2013 9:56:26 AM. by Anupam Anurag. Forum started by gauravp
3304
GFRC Construction
11251
what is the contractor per square feet price in jaipur for building residential
Last answer on 10/4/2014 8:57:50 PM. by SANJAY DUSANE. Forum started by ashok
3081
2525
2238
Good and latest Bath Room Wall Mixer
Last answer on 6/10/2013 6:00:38 PM. by elinahenry. Forum started by raghuam
3312
2312
Fire
Comparison
Orientation
Orientation of Building
Modular
How to Build Stair Steps
