Home -> Forums -> Construction -> Layout and House Plans -> lay out plan of my plot
Thu Dec 12, 2013Total posts : 1
manjeet
manjeet
Topic: lay out plan of my plot
sir i have a 5*12 sq mtrs west faced plot ,,, please give me a lay out map for 2 bhk
Fri Dec 13, 2013Post  #1
Dear Manjeet
3083
1487
Lay out Plan details
Last answer on 8/10/2016 3:13:39 PM. by Beenu Phogat. Forum started by Arun Kumar
1751
Plot size 12 by 60 feet
Last answer on 11/20/2016 11:55:01 PM. by Beenu Phogat. Forum started by Rahul
3563
Kitchen Pictures
Last answer on 8/28/2020 2:40:10 AM. by Swati Ray. Forum started by SUTANU RANA
2561
dear expert please give me lay out plan of north facing construction for 30*25ft
Last answer on 4/17/2012 5:50:14 PM. by manish. Forum started by manish
3414
I am in need of lay out plan foo house.land area 600 sq mtrs.60 ft x 90 ft.
Last answer on 8/3/2012 2:05:24 PM. by Ar. Manoj Ralen. Forum started by viqar idris
29049
3635
5755
GC 1310 plan House Plan for 30 Feet by 60 Feet plot (Plot Size 200 Square Yards
Last answer on 8/26/2020 11:41:50 PM. by S L Gupta (Civil Engg). Forum started by ravitej
2341
my plot is 25*23 size vastu plan and frunt elevation degiene in groud floor my
Last answer on 2/7/2016 10:36:39 PM. by JAI PRAKASH. Forum started by sanjay sinha
3889
9961
2267
i need a plan for 38*73 plot
Last answer on 7/23/2012 11:00:35 PM. by Ar. Manoj Ralen. Forum started by mukesh kumawat
2254
we need the plot plan for this home,
Last answer on 7/5/2011 12:10:05 PM. by kawalnain kaur. Forum started by Devendra Kumar Pandey
2991
Pls send me construction plan to 30x60 sq feet plot
Last answer on 11/3/2016 11:02:48 AM. Forum started by Kiran Surve
5833
Last answer on 7/3/2020 9:39:24 PM. by ramu771964. Forum started by RAKESH DIXIT
10835
my plot is 20x60 feet north facing suggest me a floor plan for duplex house
Last answer on 7/4/2020 2:33:24 AM. by pmlaks. Forum started by Raghothaman
3607
what will be the best plan duplex in 14X50 plot size
Last answer on 2/9/2012 8:22:29 PM. by Shama. Forum started by Shama
2209
ineed a plan for 23x 47 plot
Last answer on 7/19/2012 2:34:03 PM. by Ar. Manoj Ralen. Forum started by solairaja
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
Guideline for laying DPC
