laying of roof
Sun Oct 12, 2014Total posts : 2
rohit
rohit
Topic: laying of roof
Yesterday roof was laid, but today when I inspected I saw rori (stones used in laying of roof) all over the top, as if I couldnt see anything except it, it was all visible.
Now I am in doubt, will it effect strength of roof, because its just the 1st floor roof , 3 more roofs has to be laid,
Please reply, I am really tensed. Any measure I can take to make it strong.
I am tensed abt that visible rori
Sun Oct 12, 2014Post  #1
Dear, Rohit
you need not to worry for corse aggregate you saw at the slab top surface, only thing is that proper mixing may not have done. you keep the shuttering of slab for min 14 days do proper curing and then apply any cement based epoxy coating to top of slab, this will provide the covering to slab area also stops leakage.
secondly laying of 3- more slabs is not related to this problem
while further concreting keep good attention to compaction of concrte use 40mm needle vibrator . this will do.
Thu Oct 16, 2014Post  #2
No need to worry as it is a very common issue. please follow sanjay's suggestions.
Water filling after laying the roof (lintel)
Last answer on 3/30/2012 1:51:46 PM. by S L Gupta (Civil Engg). Forum started by dev
1692
i have constructed a new house. in all bed rooms where all pipes are laid in roo
Last answer on 7/23/2014 12:29:59 PM. by jitendra. Forum started by jitendra
Roof Gardern tips
Last answer on 7/5/2011 4:32:49 PM. Forum started by kamalesh
3087
2829
1886
Last answer on 4/12/2015 5:58:38 PM. by D.C.tandon. Forum started by SREENIVAS K
2055
Leaks in roof
Last answer on 6/20/2016 2:44:10 PM. by lalit. Forum started by Ram
1647
Leaks in roof
Last answer on 7/4/2020 12:15:12 AM. by JAI PRAKASH. Forum started by Ram
2052
1708
What are the important steps of maintenance after installation of blended marble vinyl flooring?
Last answer on 6/25/2014 1:43:17 PM. by S L Gupta (Civil Engg). Forum started by chandrapalsen
1487
Lay out Plan details
Last answer on 8/10/2016 3:13:39 PM. by Beenu Phogat. Forum started by Arun Kumar
1942
Last answer on 5/24/2012 5:08:53 PM. by S L Gupta (Civil Engg). Forum started by gaju
2003
Electrical Conduits
Last answer on 4/30/2014 3:32:30 PM. by ajaywahi. Forum started by ajaywahi
2186
8421
Roof Beam crack
1755
1548
Insulating roof using used cement bags
Last answer on 3/26/2015 1:35:41 AM. by JAI PRAKASH. Forum started by Arvind Bhaskar
4162
I want to know what size/depth is required of roof beam & thickness of RCC Roof slab ir, I want to know what size/depth is required of roof beam & thickness of RCC Roof slab for my 17'-3" length & 16'-9" width dining hall. I am attached the
Last answer on 10/17/2014 12:01:24 PM. by S L Gupta (Civil Engg). Forum started by R.Roy
7292
17'-6" length & 17'-0" width dining hall.
Last answer on 10/17/2014 11:53:30 AM. by S L Gupta (Civil Engg). Forum started by R.Roy
23
27
Guideline for laying DPC
Cooper
Aluminum
Aluminum Roof
