Home -> Forums -> Construction -> Layout and House Plans -> layout floor plan
layout floor plan
Mon Nov 18, 2013Total posts : 1
Rohit Patel
Rohit Patel
Topic: layout floor plan
 I want a layout floor plan for L=40, W=30 ,1200sqft area for flat construction .
please also provided the basement cost for above flat layout .
Wed Nov 20, 2013Post  #1
Dear Mr.Patel
1595
layout floor plan
Last answer on 11/20/2013 12:10:50 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2357
layout floor plan
Last answer on 12/6/2013 3:42:42 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
1940
9961
2056
I am planning to make a mini pool in my house. Not under ground but on ground l
Last answer on 5/12/2021 1:46:50 AM. Forum started by V K Singh
2638
Last answer on 4/5/2012 6:36:29 PM. by Gunjan Utraja. Forum started by Jajati Pattanayak
2419
Last answer on 10/18/2016 5:20:22 PM. Forum started by sandeepkelkar
Last answer on 11/15/2016 2:10:38 AM. Forum started by K Srinivasan
1945
Eastern North Road, Plot Layout HOUSE PLAN GIVE ME SIR
Last answer on 11/18/2021 10:49:57 AM. by S L Gupta (Civil Engg). Forum started by MD NIRANJAN
1560
3183
Last answer on 3/16/2017 11:32:26 AM. by S L Gupta (Civil Engg). Forum started by vijay jaswal
2489
4383
2133
Dear experts,Pl. give me a layout plan only for ground floor plan: north facing
Last answer on 4/17/2012 10:39:41 AM. by Gunjan Utraja. Forum started by mahesh
1877
Layout for Floor plan
Last answer on 1/22/2015 2:34:35 PM. by seema tyagi. Forum started by aditya
1587
2372
2363
3944
Architect's cost
Last answer on 9/22/2020 10:16:36 PM. by Cherryni. Forum started by Ajay Kostha
2689
2923
2188
2184
2790
4520
1890
2284
2264
2765
3464
2356
1965
2240
3594
2323
2090
2792
1548
2114
How to Plan Outdoor Lighting
