Home -> Forums -> Construction -> Layout and House Plans -> layout floor plan
layout floor plan
Thu Dec 05, 2013Total posts : 3
Rohit Patel
Rohit Patel
Topic: layout floor plan
kindly provide the layout floor plan for 30 feet x 40 feet plot size with south road facing. the actual size of plot is 30 feet x 100 feet but i have divided the total plot into two plot .
i have attached a sketch for this plot also. please give me a sketch/layout  for the floor .
Attachments: sketch for plot.pdf on Thu Dec 05, 2013,&n
Thu Dec 05, 2013Post  #1
Dear Patel
Fri Dec 06, 2013Post  #2
Rohit Patel
Rohit Patel
Post subject: Layout plan
           you have posted so many architectural plan on your website and i have search but did not find the same size house /floor plan . if you provide me or give me some selected house/floor plan i will be very thankful to you.
Fri Dec 06, 2013Post  #3
Dear Rohit Patel
      Send your requirement to support@gharexpert.com web site in detail showing the plot size and requirements.
1816
layout floor plan
Last answer on 11/21/2013 9:57:53 AM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
1595
layout floor plan
Last answer on 11/20/2013 12:10:50 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
1940
9961
2057
I am planning to make a mini pool in my house. Not under ground but on ground l
Last answer on 5/12/2021 1:46:50 AM. Forum started by V K Singh
2638
Last answer on 4/5/2012 6:36:29 PM. by Gunjan Utraja. Forum started by Jajati Pattanayak
2419
Last answer on 10/18/2016 5:20:22 PM. Forum started by sandeepkelkar
Last answer on 11/15/2016 2:10:38 AM. Forum started by K Srinivasan
1945
Eastern North Road, Plot Layout HOUSE PLAN GIVE ME SIR
Last answer on 11/18/2021 10:49:57 AM. by S L Gupta (Civil Engg). Forum started by MD NIRANJAN
1560
3184
Last answer on 3/16/2017 11:32:26 AM. by S L Gupta (Civil Engg). Forum started by vijay jaswal
2489
4384
Dear experts,Pl. give me a layout plan only for ground floor plan: north facing
Last answer on 4/17/2012 10:39:41 AM. by Gunjan Utraja. Forum started by mahesh
1877
Layout for Floor plan
Last answer on 1/22/2015 2:34:35 PM. by seema tyagi. Forum started by aditya
1587
2372
2363
3945
Architect's cost
Last answer on 9/22/2020 10:16:36 PM. by Cherryni. Forum started by Ajay Kostha
2690
2924
2188
2184
2790
4520
1890
2284
2264
2765
3464
2356
1965
2240
3594
2323
2090
2792
1548
2114
