Home -> Forums -> Construction -> Layout and House Plans -> layout floor plan
layout floor plan
Tue Nov 19, 2013Total posts : 1
Rohit Patel
Rohit Patel
Topic: layout floor plan
i have a plot of size L=100 feet W=30 feet.
in want to built the flat with basement . so i want the layout design of the flat and construction details for this layout. kindly provide me as soon possible.
Attachments: sketch for ground.pdf on Tue Nov 19, 2013,&n
Wed Nov 20, 2013Post  #1
Dear Mr.Patel
1816
layout floor plan
Last answer on 11/21/2013 9:57:53 AM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2358
layout floor plan
Last answer on 12/6/2013 3:42:42 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
1940
9961
2057
I am planning to make a mini pool in my house. Not under ground but on ground l
Last answer on 5/12/2021 1:46:50 AM. Forum started by V K Singh
2638
Last answer on 4/5/2012 6:36:29 PM. by Gunjan Utraja. Forum started by Jajati Pattanayak
2419
Last answer on 10/18/2016 5:20:22 PM. Forum started by sandeepkelkar
Last answer on 11/15/2016 2:10:38 AM. Forum started by K Srinivasan
1561
3184
Last answer on 3/16/2017 11:32:26 AM. by S L Gupta (Civil Engg). Forum started by vijay jaswal
2489
1945
Eastern North Road, Plot Layout HOUSE PLAN GIVE ME SIR
Last answer on 11/18/2021 10:49:57 AM. by S L Gupta (Civil Engg). Forum started by MD NIRANJAN
Dear experts,Pl. give me a layout plan only for ground floor plan: north facing
Last answer on 4/17/2012 10:39:41 AM. by Gunjan Utraja. Forum started by mahesh
4384
1588
1878
Layout for Floor plan
Last answer on 1/22/2015 2:34:35 PM. by seema tyagi. Forum started by aditya
2373
6441
Column placement for house
1421
Last answer on 9/28/2018 11:39:45 PM. by S L Gupta (Civil Engg). Forum started by Anand jaiswal
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
