layout plan
layout plan
Mon Sep 27, 2010
rosy
Topic: layout plan
hi , i m rosy ,pl. make a layout plan for south facing plot of 28by55 according to vastu . i want 2bedrooms &3 toilets,pl. send me plan as soon as possible, one thing
more i did bhoomi poojan excetly in the NE Corner.i shall be thankful to u.rosyarora@hotmail.com
Mon Sep 27, 2010
Dear rosy
1. You should contact good architect with your plot details and your requirements to be full fill your needs at the time of framing the drawing.
2. When plan of the house is cleared by you than it is necessary to prepare structural drawing showing foundation detail, column details, beam details and slab detail including provision of anti earth quack measure.
3. Cost detail estimate should be prepared so that every thing is clear to you i.e. what quantity & quality of material is required and you should get step wise cost so that at the time of allotting to work to the contractor you should know what is actual required what the contractor demanding.
4. Hire the contractor on the basis of plan, structural drawing and estimated quantity and cost.
You should contact
support@gharexpert.com
for every type of quarry and they have all type of service and supply you as many tips and help you required from time to time.
Further more there are links for start construction if you go through it there are many articles which will give all answer to your quarry including how to hire contractor etc and other link give you specimen of detail cost estimate and tips relating to your plan etc.
http://www.gharexpert.com/category/1326/Start-Construction-0.aspx?PL=2&Estimator
http://www.gharexpert.com/include/sample_estimate.pdf
3184
Last answer on 3/16/2017 11:32:26 AM. by
vijay jaswal
2491
Last answer on 7/3/2020 9:55:07 PM. Forum started by
B N SHANBHAG
9961
Last answer on 8/17/2012 11:33:38 AM. by
sandhya
2419
Last answer on 10/18/2016 5:20:22 PM. Forum started by
sandeepkelkar
2638
Last answer on 4/5/2012 6:36:29 PM. by
Jajati Pattanayak
2363
Last answer on 6/25/2011 3:05:22 PM. Forum started by
s s gupta
3945
Architect's cost
Last answer on 9/22/2020 10:16:36 PM. by
Cherryni
Ajay Kostha
2019
to help layout plan for 33ft. by 39 ft.
Last answer on 11/21/2013 10:05:07 AM. by
firoz raza
4832
Need a house layout plan for 450 sq feet land - size - 15ft X 30ft. pls help
Last answer on 5/13/2016 1:11:58 PM. by
kushagra khare
ankur gupta
2383
house layout plan
Last answer on 7/3/2020 11:09:42 PM. by
Deepak
1815
house layout plan
Last answer on 11/3/2015 11:46:11 PM. by
Deepak
1791
Last answer on 10/20/2016 1:50:26 PM. by
Aditya
6441
Column placement for house
Last answer on 9/13/2017 11:49:12 PM. by
sanjay singh
Parmeswar Giri
1421
Last answer on 9/28/2018 11:39:45 PM. by
Anand jaiswal
Dear experts,Pl. give me a layout plan only for ground floor plan: north facing
Last answer on 4/17/2012 10:39:41 AM. by
mahesh
1943
layout plan
Last answer on 3/19/2013 10:28:59 AM. by
Anupam Anurag
dr. saurabh
2141
Layout plan
Last answer on 12/26/2011 12:25:30 PM. by
ravi at Dalmia
Geetha Pattabiraman
2217
layout plan
Last answer on 9/9/2011 3:29:00 PM. by
kawalnain kaur
aamertoor
2923
Need Layout plan for a duplex house
Last answer on 11/14/2010 10:39:10 PM. by
Partha Sarkar
