Home -> Forums -> Construction -> Start Construction -> leakage.
leakage.
Thu Jul 18, 2013Total posts : 1
Topic: leakage.
Dear sir
In my home sintex water tank is leakage.that is old sintex water tank also one contractor did repair work.but after some day again same problem.Can any one suggested me to this problem so that leakage must stop.
Fri Jul 19, 2013Post  #1
Dear Chethan
          It is better to change the water tank. By spending the money on repair is to no in use.
2535
How to arrest leakages through expansion joints.
Last answer on 11/20/2009 10:16:24 AM. by Girish. Forum started by Jagadesh Babu
2298
3121
3370
2931
2321
2767
roof leakage
3980
Roof leakage
2151
seal coat on roof
Last answer on 9/19/2010 11:16:18 PM. Forum started by viswanath
1910
There's a basement space in a building and it locates at backyard of lower level
Last answer on 10/24/2013 11:34:35 AM. by S L Gupta (Civil Engg). Forum started by parth
2291
2380
leakage in new slab
2055
Leaks in roof
Last answer on 6/20/2016 2:44:10 PM. by lalit. Forum started by Ram
1647
Leaks in roof
Last answer on 7/4/2020 12:15:12 AM. by JAI PRAKASH. Forum started by Ram
1721
Inverter /solar line safety
Last answer on 6/17/2021 12:00:43 AM. Forum started by Sajeev
1552
Leakage question.There is leakage in the floor below my bathroom. From the apart
Last answer on 10/21/2014 11:39:49 AM. by S L Gupta (Civil Engg). Forum started by D.P.S
1525
Cost for Polyurethene Grouting for Leakage from Flat Above
Last answer on 3/28/2015 6:24:30 PM. by JAI PRAKASH. Forum started by Unmesh
3487
Water leakage from the Swimming Pool
Last answer on 8/5/2020 12:58:17 AM. by S L Gupta (Civil Engg). Forum started by S. K. Agarwal
2912
RCC ROOF LEAKAGE
Last answer on 12/5/2012 1:40:32 PM. by S L Gupta (Civil Engg). Forum started by sivarajen
3310
2312
Electric
Preventive
ACC
ACC Sheet Roofing
Importance
