Home -> Forums -> Construction -> Cement Concrete -> leakage in new slab
leakage in new slab
Fri Jun 26, 2015Total posts : 3
milind
milind
Topic: leakage in new slab
I am constructing new house. After completion of slab , next day it is observed that water is leaking in 2-3 locations. After 8 days 1 leakage is stopped but 2 locations still have leakage. It  seems that this may be due to not doing proper compaction.
Pl. provide suitable suggestion
Milind
Fri Jun 26, 2015Post  #1
Dear Milind
        This problem is either due to defect in compaction or putting  the mix which is lifted from side not having proper ratio but have more bazri and less sand and cement contents.
For remedy clean the affected area, make the area rough and  put cement water mix and finish the top with cement and coarse sand mortar. properly and cure properly.
The second option after making top surface rough pure cement coarse sand and 6mm to 10 mm bazri mix in the ratio 1;1.5;3 on the affected area overlapping the area at least 6'' on all side and thickness of mix should be 2'' thick and thickness  will be cover by floor or tile terracing cure the area.
Fri Jul 03, 2015Post  #2
It clearly suggests that slab was not properly constructed. This points are the defects but are very common as well due to issues with the material ratio, shuttering, labour etc. That can be fix by having a layer of cement mix with water done on the entire lantel before tiles. The more fix would be done by having proper plaster below it later.
Sat Jul 15, 2017Post  #3
rajeev
rajeev
Post subject: cracks on linter just after the laying
cracks on linter just after the laying, plz tell me the reason
Attachments: IMG_20170715_154337.jpg Sat Jul 15, 2017,&n
9893
3979
Roof leakage
2321
2297
3121
2535
How to arrest leakages through expansion joints.
Last answer on 11/20/2009 10:16:24 AM. by Girish. Forum started by Jagadesh Babu
3370
2865
Steel calculation
2524
2151
seal coat on roof
Last answer on 9/19/2010 11:16:18 PM. Forum started by viswanath
2125
CRACK IN CENTRE OF SLAB
2766
roof leakage
2931
3163
APP membrane
2148
Sunken slab
Last answer on 1/17/2021 5:51:16 AM. by freekundli. Forum started by Bhaskara
4010
labor rate for RCC work
2562
4054
3469
Cost of concrete walls
1793
STP
3107
3651
4349
rate comparison
3204
Concrete Mixture
3142
sloping roof
2090
15805
6470
1528
Guide me
5119
2535
Civil Eng Stair Design
2535
Related to Sunken Slab
1858
1998
Concrete Hollow Block Masonry
2414
roof concrete
3199
Ready Mix Concrete
Happy
Happy New Year 2009
Electric
Preventive
Bedroom Makeover
