Home -> Forums -> Construction -> Steel -> length of bar tor in RCC column
Fri Aug 22, 2014Total posts : 2
Rohit Patel
Rohit Patel
Topic: length of bar tor in RCC column
  explane the  length of sariya which is used in RCC column, can its length varies according to the height of roof.
Fri Aug 22, 2014Post  #1
Dear Patel
     The length of MS Steel bars in RCC COLUMN is from foundation to top of roof.
Sun Oct 12, 2014Post  #2
dear
try to keep full lenght bar, if not possible provide lap 50d for columns
d= dia of bar , for expl. lap= 50 x 16 mm = 800 mm lap lenght
13772
overlap length to steel
2036
2707
2302
2033
2898
RCC Roof
3753
2131
what are requirements of RCC cantilever length?
Last answer on 12/24/2014 11:46:06 AM. by S L Gupta (Civil Engg). Forum started by syed basha
2069
beam and column
8965
Last answer on 9/11/2020 2:17:26 AM. by hemant. Forum started by hemant
2719
13755
2121
underground water tank
15582
3837
Roof Beam
3013
2684
steel requirment
15582
1992
Residential complex
4367
RCC Columns
3238
7478
Bar Bending Schedule Software
2521
steel
29941
2612
9362
2258
Current iron rod price
2605
1885
Steel Erectors
2382
3266
13772
2160
Type
HSD
TMT
Dining
Dining Chairs and Bar Stools
