Home -> Forums -> Vastu -> Drawing Room -> lift or elevator on the north east wall of flat
Tue Jan 22, 2013Total posts : 3
guru
guru
Topic: lift or elevator on the north east wall of flat
Hi our flat is having lift or elevator on north east wall of our flat. Is it bad to have like that? please help me
Wed Jan 23, 2013Post  #1
Flores Lopez
Flores Lopez
The best direction for staircase and lift is south east but as your lift is in north east you should place a Crystal quartz in the north east to reduce the negativity.
Wed Jan 23, 2013Post  #2
Pavan
Pavan
Post subject: lift or elevator on the north east wall of flat
As per Vastu reduction of load in N/NE/E and addition in S/SW/W is always advisable.
Lift forms a hollow duct in the building that reduces the load in that particular zone. Also there is a Sump/Depression at the base level of the lift again this is a positive sign.
Other important factor, there should be a stair case adjacent to your Lift, which again is a load in that direction. So stair case forms a load balancer to the lift duct. So the laod in this zone is already balanced.
Other important factor is in what zone of the building is your Flat located and what zone is the lift located(Secondary Vastu). Then in what zone of the Plot your flat is located and what zone is the lift located (Primary Vastu). if it is an appartment, what floor you leave on.
These are multiple factors that one needs to understand before making any Decision.
Regards.
Pavan Matkar
Wastu Wimarsh
Tue Feb 14, 2017Post  #3
vijay
vijay
Post subject: placement of lift/elevator
i intend to buy a flat which is located in the N-E zone of the apartment and another flat is located in the S-E zone of the apartment, there is a lift in between the two flats. The lift is located in the S-W part of my flat. The stair case is located in the S-W part of another flat. Can I buy the flat which is having lift which is beside my master bedroom i.e., S-W part?
3693
My flat north , east corner wall attached lift is it good or bad .?
Last answer on 4/17/2017 12:54:32 PM. by S L Gupta (Civil Engg). Forum started by Srinivas
3102
there is lift or elevator in southwest side of my flat and staircase at north of
Last answer on 7/3/2020 11:56:30 PM. by Pavan. Forum started by eswari
2051
can lift can touch north wall of the flat
Last answer on 8/31/2017 12:24:48 AM. by S L Gupta (Civil Engg). Forum started by venkat
1995
lift can touching north wall ?
Last answer on 8/31/2017 12:25:43 AM. by S L Gupta (Civil Engg). Forum started by venkat
4463
2865
my north east direction has lift. can i utilise my home.
Last answer on 2/27/2014 9:47:54 PM. by thomas george. Forum started by senthil
3189
for a flat
Last answer on 10/13/2010 5:18:56 PM. by lokareddy. Forum started by shrawan
2227
our flat is south facing flat and we main room is in North east of corner .. pls
Last answer on 10/25/2013 11:30:20 AM. by S L Gupta (Civil Engg). Forum started by lipika Tandon
6965
VAASTU FOR APARTMENTS
1804
My house which is facing frony wall is facing North but while construction by mi
Last answer on 7/23/2011 7:19:07 PM. Forum started by Manjeet singh
2841
Main entrance of my flat is in south west corner and kitchen is in north east co
Last answer on 3/5/2021 2:47:48 PM. Forum started by M.P.Upadhyay
2777
what happens common stair case comes to north or northeast wall of the flat?
Last answer on 5/27/2013 12:51:23 PM. by GULSHAN RAI GULATI. Forum started by gantag
1607
I have north east missining in my flat.What adverse effect it has on me and othe
Last answer on 3/30/2010 1:35:32 PM. by Ajit Tareeka. Forum started by Raman Mediratta
6397
Last answer on 3/5/2021 3:03:59 PM. by GULSHAN RAI GULATI. Forum started by RAMESH ALURKAR
2738
Placing of Pooja temple
Last answer on 8/19/2020 7:32:08 AM. by Amit Hasija. Forum started by Digvijay Baghmar
2843
Last answer on 9/23/2013 11:39:54 AM. by S L Gupta (Civil Engg). Forum started by Neha sanghvi
3480
i need to know about the lift position and can the lift come inside the house
Last answer on 12/31/2020 2:31:44 AM. by Karan. Forum started by vkausalya
3169
Entire south is open
Last answer on 1/1/2013 8:15:45 PM. by Pavan. Forum started by raj_karelia
2483
Tips for Small Space Bathroom
Last answer on 3/29/2010 3:28:59 PM. by S L Gupta (Civil Engg). Forum started by vankamardi
3663
3073
2303
2331
3397
2247
5110
1834
7089
2545
2131
1711
1813
1820
2064
5806
2661
7275
7513
2691
Canvas
Canvas Wall Art
Wall
Wall Decor
