Cement Concrete
lift pit water proofing
Fri Nov 02, 2012
anand
Topic: lift pit water proofing
how to do best water proofing for lift pit??
Mon Nov 05, 2012
Dear Anand
You should visit gharexpert.com website basement section in construction, where you find lot about basement construction. See the link below
http://www.gharexpert.com/articles/Basement-1505/Water-Proofing-Treatment-Basement_0.aspx
Cement Concrete-Construction Questions (39)
6414
Last answer on 8/17/2012 11:30:19 AM. by
gangula
2474
Septic Tank Design
Last answer on 4/30/2013 3:22:27 PM. by
Jitender Suhag
Jitender Suhag
2232
Last answer on 1/10/2016 8:50:43 PM. by
venkatesh
2766
Last answer on 9/21/2016 12:04:43 AM. by
Pawan kumawat
Satvinder kaur
2236
Last answer on 12/19/2013 10:54:10 AM. by
MOHD WAKEEL
MOHD WAKEEL
3163
APP membrane
Last answer on 4/7/2021 11:05:28 PM. by
upsersv2e
i need to know about the lift position and can the lift come inside the house
Last answer on 12/31/2020 2:31:44 AM. by
Karan
vkausalya
3828
ROOF WATER PROOFING / TANKING
Last answer on 11/17/2009 10:47:13 AM. by
Girish
Girish
2894
Terrace water proofing
Last answer on 7/13/2020 12:26:53 AM. by
ravi pachipala
2041
Soak pit location in industrial plot
Last answer on 5/21/2019 1:35:08 AM. by
navin
3965
water proofing of water tank
Last answer on 1/12/2021 1:06:05 AM. by
water harvesting pit location for 200 yards individual house
Last answer on 1/16/2015 12:43:58 AM. by
nagaraju
1958
Last answer on 5/4/2010 1:13:49 PM. by
amarnath pandey
2807
What is the cost of Home Lift capacity for four persons for four floors building
Last answer on 7/16/2014 7:56:03 PM. by
A Prasad
7194
Where shd be a lift in house
Last answer on 5/28/2014 2:01:32 PM. by
rana
Last answer on 5/9/2016 11:34:49 AM. by
soumya
1658
i have lift in the SE corner of kitchendiscuss the effects good or not
Last answer on 8/8/2016 2:23:42 PM. by
lakshmanachary chennoju
3717
My flat north , east corner wall attached lift is it good or bad .?
Last answer on 4/17/2017 12:54:32 PM. by
Srinivas
2005
lift can touching north wall ?
Last answer on 8/31/2017 12:25:43 AM. by
venkat
3469
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
1792
STP
Last answer on 5/18/2021 1:47:12 PM. by
Nijesh Ramraj
3106
Last answer on 12/31/2020 1:53:26 AM. by
N.S.BISHT
Pujesh Mallick
3651
Last answer on 9/17/2020 9:19:38 AM. by
Razi
4348
rate comparison
Last answer on 7/4/2020 2:15:33 AM. by
aammiitt
aammiitt
3203
Concrete Mixture
Last answer on 7/4/2020 2:11:26 AM. by
Ar. Manoj Ralen
Navneet Shahrawat
3142
sloping roof
Last answer on 7/4/2020 2:00:34 AM. by
ekonagu
2090
Last answer on 7/4/2020 1:58:38 AM. by
abdul
15805
Last answer on 7/3/2020 11:48:29 PM. by
Mohan
6469
Last answer on 4/5/2018 12:39:19 AM. by
Sanzana Hosen
2379
leakage in new slab
Last answer on 7/15/2017 3:57:04 AM. by
rajeev
milind
1527
Guide me
Last answer on 3/22/2017 12:35:27 PM. by
Subash
5118
Last answer on 1/25/2017 5:30:02 PM. by
vinod singh
2535
Civil Eng Stair Design
Last answer on 2/1/2016 1:27:20 PM. by
swarooppratap
2535
swarooppratap
Related to Sunken Slab
Last answer on 10/25/2015 8:30:24 PM. by
SOUNAK SAMANTA
1857
Last answer on 8/22/2015 7:13:59 PM. by
bala
1997
Concrete Hollow Block Masonry
Last answer on 7/2/2014 11:26:57 PM. by
s p kataria
2414
roof concrete
Last answer on 5/22/2014 1:50:02 PM. by
sakthi
3199
Ready Mix Concrete
Last answer on 10/7/2013 11:24:46 AM. by
sck
Damp Proofing
Basement Design Ideas
Guideline for laying DPC
