little detail required
Fri Jan 03, 2014Total posts : 1
gaurav
gaurav
Topic: little detail required
hello experts I would like to know the various quality of flush doors available with or without chokhat. I m building my home n would like to be in budget so asking u. which kind of wood u would recommend me for chokhats n flush  doors...somebody told me chokhat of chaap is okey bt it catched termite my idea is for teak.would it be costlier or too expensive.?
Sun Jan 05, 2014Post  #1
Post subject: wood recommend for chokhats
Hello...! Gaurav.The teak wood is too expensive for Frames of door/windows.The Sal wood ( Sarai)is good for frames and it can be covered with teak wood molding beads to give a look of Teak wood.The Sal wood is a very strong and durable ,earlier it was used under Railway lines as Sleepers.here at Jabalpur its rate is around 1400 to 1600 per Cu.ft. For Door shutters ..Teak wood panel door or Teak wood frame with teak ply can be used,
Attachments: 100_1367.JPG Sun Jan 05, 2014,&n
COST DETAIL REQUIRED
Last answer on 12/24/2013 11:43:24 AM. by S L Gupta (Civil Engg). Forum started by ANNA.B
1940
2123
2675
i want to know the dimensional details and plan view of this stair case and also
Last answer on 10/6/2009 10:39:25 PM. by Priti Arora. Forum started by G.K.Ramesh
2377
3320
dear sir, iam purchased plot 222 sq.yards ,south face ,send u r contact details,
Last answer on 2/3/2021 8:51:26 AM. by JAI PRAKASH. Forum started by kishore
2137
BUT I WANT A LITTLE SIMPLE DESIGN IN MAROONISH RED AND GOLDEN YELLOW WITH SPOT L
Last answer on 3/2/2012 5:07:23 PM. Forum started by DORIS
487
How can I relax a little and have a good time?
Last answer on 2/22/2022 6:41:35 AM. Forum started by John Staples
7716
showroom
Last answer on 11/24/2020 10:57:14 PM. by JAI PRAKASH. Forum started by ankur
8820
Last answer on 7/3/2020 10:16:59 PM. by JAI PRAKASH. Forum started by sandeep yadav
2980
Query regarding Estimation and details required for swimming pool construction
Last answer on 12/28/2011 10:10:25 PM. by Edward. Forum started by Mukesh Singh
2284
great design,but a little bit compacted,more space,less wares,that is well arran
Last answer on 3/31/2010 6:29:15 PM. by Ajit Tareeka. Forum started by joel
2213
Last answer on 12/14/2010 7:35:48 PM. Forum started by Rakshit
1763
Dear Gupta sir,i am ready to get a detailed estimate for my house to be construc
Last answer on 5/4/2013 2:25:17 PM. Forum started by nithun
2681
My House design
1979
2866
Steel calculation
1599
How much Marole required
2016
required plan for 15/40 site 2bhk with vastu
Last answer on 1/23/2022 3:38:51 AM. by TanyaHerrera. Forum started by mangala
24
28
