Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> load bearing walls
load bearing walls
Wed May 12, 2010Total posts : 3
mohan
mohan
Topic: load bearing walls
hi, my proposed house which is 43' x 31' has two bed rooms 16x10, a hall 16x16, a kitchen,dining a sitout and two attached toilets. Main wall or outer wall is 9" and centre walls( east to west and North to south)are also 9" and rest of the walls are partition walls (4.5"). Is this enough for load bearing. pls help
Wed May 12, 2010Post  #1
mohan
mohan
The above question asked by me. This house is a 2 storey building  having the sames plan  for Ist floor too.
Thu May 13, 2010Post  #2
Post subject: Reply-Load bearing walls
Dear Mohan,
9” thick brick walls may serve the purpose of load bearing walls. It is better if you take structural advice from any structural engineer by sending plan of the house and nature of the soil. Structural engineer would supply the detail of foundation according to load coming on the wall, which is most important in case of load bearing walls and also give the position of beam and RCC bed plate etc. This service (in paid) is also available with experts at GharExpert.com
S.L.Gupta
Thu May 13, 2010Post  #3
mohan
mohan
Thankyou sir for your immediate reply.
7257
4128
2427
RCC ROOF Requirements
Last answer on 5/22/2013 8:47:10 AM. by Rajesh. Forum started by Rajesh
3013
1732
2132
Load bearing
Last answer on 1/17/2014 12:05:30 PM. by S L Gupta (Civil Engg). Forum started by Syed Shahed
2256
2525
2616
COLUMN nd LOAD BEARING
10047
2865
Bricks
3992
1908
Brick or ACC block
1745
I have house in Ahmadabad. Since six months i am finding cracks in three walls.
Last answer on 5/30/2017 11:03:31 AM. by S L Gupta (Civil Engg). Forum started by Naimish Patel
2627
Whether 6 x 8mm TMT bars are enough for rcc belt over rubble foundation for 2 story house?
Last answer on 9/30/2016 2:16:48 PM. Forum started by vinu
1797
1747
19153
Last answer on 7/3/2020 10:47:35 PM. by S L Gupta (Civil Engg). Forum started by Techman
24765
5811
3792
9885
2670
4628
4143
2865
5006
3656
1865
2800
2610
2373
2462
2638
1807
3608
6254
Canvas
Canvas Wall Art
Specification of Steel
Wall
Wall Decor
Paint
Wall
Wall Accents for Your Rooms
