lobar work quantity
lobar work quantity
Tue Apr 08, 2014
shaik khaja nayab rasool
Topic: lobar work quantity
hai sir ....how much work can we expet (in metercube) for a person in one day(8 hours) male and female as per norms ...1)concrete work
2)earth work excavation
Wed Apr 09, 2014
Dear Rasool
The progress of earth work depends on the kind of soil that it is hard, normal or sandy soil. The progress also depends on the nature of work, weather also effect on the progress. In general 100 cft excavation can be done by one pers
on.
For concrete It depends on the ratio of concrete, Raw material dumping distance, micine mixed or hand mixed etc.
In general 20 to 30 cft of concrete.
Sat Apr 22, 2017
D A VRAO
how many days it takes for spreading ,compacting graded moorum 4.95 thick and compacting to 95%CBR with 10 to 12T
2679
shuttering calucation
Last answer on 4/8/2014 1:21:34 PM. by
3003
Last answer on 1/5/2022 12:45:53 AM. by
Last answer on 6/24/2013 9:59:46 PM. Forum started by
Last answer on 10/12/2014 9:03:20 PM. by
rajeev
20152
Last answer on 2/18/2022 6:35:57 PM. by
SusanBones
mani
3401
Bathroom Cleaning Tips
Last answer on 6/10/2019 1:04:58 AM. by
jaswinder Singh
Nitesh Patel
2682
Last answer on 10/12/2014 8:53:52 PM. by
nith_piyush
4188
What are the normal fees for architect, civil engineering drawing, quantity surv
Last answer on 5/27/2013 11:48:46 AM. by
Vaibhav Jain
Anil Sood
2355
software
Last answer on 12/1/2021 6:05:00 PM. by
Last answer on 7/30/2014 10:51:01 AM. by
Dhananjay
13780
Last answer on 1/26/2017 11:24:59 AM. by
Madhankumar
upendra
1830
Last answer on 7/3/2020 11:35:37 PM. by
Ganpat B Chaudhary
3111
Last answer on 10/5/2020 10:59:59 PM. by
DEVANSU
2600
JOINERY WORKS
Last answer on 12/11/2013 11:18:00 AM. by
Plaster work
Last answer on 2/15/2022 8:09:55 AM. by
AleksShamles
Alok Das
1770
Last answer on 1/19/2022 5:51:57 PM. by
Girish
1674
Last answer on 3/27/2017 12:36:40 PM. by
Girish
2161
Last answer on 12/26/2014 1:00:45 PM. by
Last answer on 1/23/2022 3:40:26 AM. by
Checklist for Painting Work
