Home -> Forums -> Construction -> Ground work -> How long we should not remove the shuttering
Sun Dec 14, 2014Total posts : 2
Navratan
Navratan
Topic: How long we should not remove the shuttering
I am currently constructing a house with RCC Roof Lanter area 3600 sqft.  I am done with almost everything , my only query is for how long we should not remove the shuttering of this RCC Roof Lanter, as some guys who came from Tata Steel said I should keep it for abt 21 days after pouring RCC mix on the lanter. Please advise . Awaiting your quick reply as I am planning for lanter this week itself.
Also it would be of great help if you can provide me your private  email, as I wish to send you site pics too for other clarifications.
Thanks n rgds
Navratan
Mon Dec 15, 2014Post  #1
Dear NavRatan
         The following is the schedule for removing the shuttering from RCC slab.
Precautions for Cantilever slabs and Beams
  • While doing shuttering of a cantilever part, outer edge of shuttering is 1” to 2'' higher than inner edge with the wall.
  • The bracing of vertical supports for cantilever portion should be tied to vertical supports of internal slab.
  • The concrete should be laid on cantilever portion very gently.
  • The shuttering should be removed after 28 days.
Recommended Period for Removal of Shuttering
Fri Jan 16, 2015Post  #2
At least 2 weeks.
25609
CURING TIME FOR RCC ROOF
2568
11300
1421
Last answer on 9/28/2018 11:39:45 PM. by S L Gupta (Civil Engg). Forum started by Anand jaiswal
1006
Shuttering and labour cost 1600sft
Last answer on 7/3/2020 11:13:46 PM. by S L Gupta (Civil Engg). Forum started by Sri
2248
3289
what is the cost of rolling shutter per sft what guage should br used
Last answer on 8/27/2013 9:57:24 PM. by kiran kumar 3k. Forum started by kiran kumar 3k
2672
shuttering calucation
Last answer on 4/8/2014 1:21:34 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
3874
centering shuttering formwork
Last answer on 5/10/2011 5:09:34 PM. by S L Gupta (Civil Engg). Forum started by navin kotian
2945
Can I get 300cm long tv unit
Last answer on 8/16/2018 12:51:10 AM. by S L Gupta (Civil Engg). Forum started by sadekhussin
2642
vastu tips to keep the house lady in good health and long life
Last answer on 12/8/2020 10:50:18 PM. by S L Gupta (Civil Engg). Forum started by rajesh singh chandel
2244
How long do your kids use a computer or smartphone for games and movies?
Last answer on 12/6/2021 3:35:47 AM. by pilahak911. Forum started by aglar
2172
How to Protect Wood Furniture
Last answer on 9/8/2011 4:16:04 PM. by davidbanks. Forum started by Justin T
3293
2909
Shuttering Plywood
Last answer on 11/17/2009 9:26:16 AM. by Girish. Forum started by Girish
6695
1538
cubboards partitioned with kadapas
Last answer on 8/5/2015 4:44:15 AM. by JAI PRAKASH. Forum started by ashwini dharashivkar
Shuttering Plywood
Last answer on 12/4/2011 6:16:40 PM. Forum started by Girish
3940
Cantilever porch
Last answer on 11/17/2021 10:04:24 AM. by S L Gupta (Civil Engg). Forum started by Capt. Devendra Kumar
2998
8161
software
3900
2730
1833
lanterns
3134
false ceiling
2245
about construction
1786
4154
Cement Coba
3077
Water Harvesting System
1677
1758
water tank
2058
1760
1634
Pool construction cost
1996
2738
Regarding roof beam
Fire Stair case
2646
2374
super structure
Surface
Carpet
Carpet Cleaning Tips
Centering
Kitchen Cabinets
Protection
Protection against Mosquitoes
A few diseases like Dengue and Chikungunya have resulted in expressions of confusion all around. These diseases are tr..
Protect
Protect Your Family from Dust
Advanced
Advanced Home Security Tips
In today’s hi-tech world your home needs some extra high security systems to avoid theft and beat terrors. So make you..
