m15 cost vs m20 cost
Tue Dec 29, 2015
Rohit Sharma
Topic: m15 cost vs m20 cost
assuming If we are building 11feet height column( not including column footing base). what will be the cost difference to build m15 grade column and m20 grade column.
Coarse sand price rs2500 for 100cub/ feet(1 trali)
bajri rs2000 per 100 cub/feet
cement 270 per 50kg bag
column size 9"*9" having 6 no. 12mm bars
11571
Last answer on 3/25/2010 6:08:56 PM. by
ch jaya bharath azad
shridhar
2939
Last answer on 7/4/2020 12:14:00 AM. by
S.Krishnan
Sakthivel
2667
Want to know the Strength of the Roof Slab
Last answer on 3/8/2011 5:41:21 PM. by
Sambasiva Rao Ravuri
3252
Roof Concrete Strength
Last answer on 10/12/2014 8:43:10 PM. by
Jahankumar
32477
Cost of RCC Pillar
Last answer on 2/23/2022 11:59:24 PM. by
Subhajit Kundu
2129
RCC SLAB
Last answer on 8/10/2020 11:19:07 PM. by
nagendrabk
6083
What is construction cost
Last answer on 12/1/2020 5:38:30 AM. by
manoj
2787
what is the cost of living room forinterior designing and all the cost of rooms
Last answer on 7/3/2020 10:01:06 PM. by
priyanka
2446
Used M15 (1:2:4) mix ratio with PPC cement for casting ground floor house roof slab
Last answer on 2/21/2017 12:28:02 PM. by
3826
comments required
Last answer on 11/18/2021 7:51:18 AM. by
gangula
3961
Last answer on 7/3/2020 10:06:39 PM. by
raghuam
srihari
2728
Last answer on 12/27/2016 4:34:02 PM. by
sathis
2601
Last answer on 11/8/2017 1:59:13 AM. by
Sheila
2630
Last answer on 6/8/2015 11:10:06 AM. by
sira
1956
HOW MUCH COST WILL BE 3 BHK IN 1500 SQUARE FEET, PLEASE GIVE DETAILWISE MATERIAL
Last answer on 12/9/2015 11:40:05 AM. by
manoj
3064
Dear Sir,What is the concrete grade used(M15/M20 etc.) in roof casting of normal
Last answer on 12/9/2021 10:16:53 PM. by
pal
2157
Last answer on 1/27/2017 1:14:54 PM. by
Satishkumar
Satishkumar
1396
how much cost to above tipe of elivation
Last answer on 7/4/2020 2:24:17 AM. by
Rayapati Kowsalya
1741
Last answer on 5/25/2021 9:21:56 AM. by
HardissonHard
Sree
2442
