Home -> Forums -> Construction -> Steel -> How mach steel required for 1400 sq ft roof?
Wed Jan 21, 2015Total posts : 3
Balaguru
Balaguru
Topic: How mach steel required for 1400 sq ft roof?
Dear Sir/Madam,
How much steel required for 1400sq. ft. roof floor?
Roof thk. will be 1 feet.
please advise me
Thu Jan 22, 2015Post  #1
Dear Balaguru
           The quantity of MS Steel bars is depends on the design of slab/ roof.The thickness of roof slab is from 4'' to 6'' according to design but not 1feet. For 1400 sqft slab MS Steel is required 1700 kg to 1900kg.
Sat Jan 24, 2015Post  #2
2000 kg.
Wed Sep 26, 2018Post  #3
       Thank you.
191900
2866
Steel calculation
3494
15807
2745
13755
721
2184
Marble required for flooring
Last answer on 1/7/2022 12:44:11 AM. by S L Gupta (Civil Engg). Forum started by K. Basu
2811
Last answer on 12/31/2020 2:51:38 AM. by S L Gupta (Civil Engg). Forum started by SHAILESH
5691
42597
Labour Cost for Roof RCC work
1875
2770
Last answer on 7/12/2018 5:49:08 PM. by S L Gupta (Civil Engg). Forum started by Hameed
14312
20 sq ft and 50 sq ft how can i make house with vastu
Last answer on 12/24/2012 3:50:59 PM. by S L Gupta (Civil Engg). Forum started by saravanan
RCC + Brick work estimate for 2400 sq ft construction- Update
Last answer on 5/7/2014 4:12:37 PM. Forum started by nilesh
11102
2684
steel requirment
15582
1992
Residential complex
4367
RCC Columns
3238
7479
Bar Bending Schedule Software
2521
steel
2613
9362
2260
Current iron rod price
2606
1885
Steel Erectors
2382
3266
13772
overlap length to steel
2160
2539
What is acre
Steel
Steel Roofing
Roof Flashing
Is the ceiling of your house leaking? Apply roof flashing technique to prevent water leakage from the roof. Roof flash..
Cooper
