Home -> Forums -> Vastu -> Drawing Room -> main entrance location
Mon Oct 01, 2012Total posts : 4
svk
svk
Topic: main entrance location
in my block i hve main entrance in the extreme south west corner ( which as per the vastu knowledge is not good). as it main entrance i cant alter it
its specifically in 220 - 240 degrees & in 220 degrees its marked as SW
hope i hve given clear idea
i wil be placing  ganpati photo in the north wall just opposite the main entrance.
wht else can be done
Mon Oct 15, 2012Post  #1
Post subject: Remedies for south-west enterance
Dear Mr. SVK,
Rahu is the lord (swami) of the south west direction. So it is advised the installing a Rahu Yantra in south-west direction may deflect the negative energy.
There may be some more solutions for the problem described by you, depending on location, road and directions of the site your house). So it is advised that you may contact a vastu architect in your location for better on-site remedies and solutions.
Fri Dec 14, 2012Post  #2
nehamehta
nehamehta
Post subject: Vastu Tips For Main Entrance Door
Tips to Place the Main Door According to Vastu
  •      The main entrance door of the house should be comparatively larger than the other doors in the house.
  •      Ensure that the shutters of the doors open up towards the inside of the house. It should also have two shutters according to Vastu.
  •      The main door placements should neither be at the center nor in the extreme corners.
  •      If the door is facing North, East or South, then place it in the North-East corner of the wall. If the main door is West facing then it should be placed at the South-West corner.
  •      If you are confused on which side the entrance should be facing, then divide the house into nine parts. The main door should be in the fourth division from the left side and sixth division from the right side of the house construction. It is better to consult a Vastu professional to mark the entrance.
  •      The main entrance door should be made of high quality material like teak or mahogany.
  •      Construct the main door placement in such a way that no shadows fall over it.
  •      Decorating the entrance with pictures of Gods like Lakshmi, Ganesh, Kuvera or signs of OM and Swastika are considered as auspicious.
<!--[if !supportLists]-->
Once you have placed your main door at the right place in a right way based on these Vastu tips, avoid placing footwear in front of the door. It may spoil all the auspicious part of your main door.
       Regards:
Attachments: VG-logo1 (1).png Fri Dec 14, 2012,&n
Tue Jan 01, 2013Post  #3
Pavan
Pavan
Post subject: Suggestion for Main Entrance door.
As you have mentioned (Block), I assume this is a flat. If it is a Flat in that case nothing much can be done. But Before considering SW of your block, Consider the Zone that your flat is in Primary Vastu and Secondary Vastu. Primary vastu is the Plot on which the Building is constructed, Secondary vastu is your Building (Bhavan) and Finally the Tertiary vastu is your Block (Flat).
Apart from this I agree with Amit, There are multiple factor that needs to be considered. Also since you have the main door in the SW direction (corner) of your Block that means you must be having baclony or terrace on the East or North Side, which is a very good sign.
There are multiple options to recitfy the defects of the SW Direction
A good suggestion would be to consult an expert before making any changes.
Thu Jan 24, 2013Post  #4
sonigupta
sonigupta
Post subject: Vastu Shastra tips for your main entrance door
The main door is the passage which creates life in a home. One should pay great attention to the main door and the main windows as per the vastu shastra.
There are various aspects like the placement of the main door, the placement of the main windows, the direction of the main door and so on. A person enters the home through the main door and hence the main door should produce positive energy each time a person walks in. This positive energy from the main door is correlated to the entire portion of the home. An entrance door should be positioned in a way where it can activate the most beneficial energy. Following are some tips which can help you position your main entrance door as per vastu shashtra.
Choose an auspicious day:
One can place the main door on a fixed auspicious day after performing a vastu puja. The location of the main door plays an important role as you need to figure out on which place can be apt to place the main door. You can do this by standing in front of your home and imaginarily dividing your home into two parts where the door can be placed towards the center. It can be either in the left or the right half based on the direction of the door.
Door position according to the directions;
North:
The door should be in the left half when facing the house. Avoid placing the door in the right half (North-West). Placing the door in this direction will allow ample amount of sunlight throughout the day. The door should be placed in the center of the wall and the windows should be kept in the North-East. Avoid placing the door near the corner of the walls.
West:
The door can be placed in the left half, facing the house. Avoid positioning the door in the right half of the house as more windows are supposed to be positioned here for a constant sunlight throughout the day. Avoid the opening in the south west direction. If you have a door in the west ensure that you have a parallel door in the east which can allow maximum useful UV rays.
South:
A door positioned in the south shouldn’t be placed in the center of the building and should be placed in the right half of the home. Avoid placing the main door in the south-west direction as this might harm you with the hot infrared rays.
East:
The door can be placed in the right half facing towards the north east direction. Avoid positioning the door in the south east direction. The door should be placed in the center of the wall and the windows should be placed in the north-east direction.
Do not have a main door directly facing the opposite home:
Always remember that you do not place your main door to the opposite home as it will be quite uncomfortable when both the doors are open which can ultimately result in a peek of both the homes.
Do not have the main door facing an abandoned and deserted building:
Avoid placing your main door towards a deserted and a rundown building as this can create negative vibes and you will have a scary and cold sight every time you open the door.
Have the entrance gate and the entrance door on the same side:
Always have the entrance gate and your entrance door on the same side as the vastu principles do not consider it auspicious to have the entrance gate and the entrance door on the opposite direction. Also it is considered as an inconvenience to the guests.
Do not have an underground tank, septic tank under the main entrance door:
This is because if the tank has to be opened and cleaned, it will be very inconvenient if it has to be done right in front of the main door.
Do not have the main entrance door in the corners of the home:
It is advisable that you do not have the main entrance door in the corners of the home as this can result in a difficulty while placing furniture at home. Corners in a home should be left vacant for movement.
Do not have a wall in front of the entrance door:
Do not have a wall directly in front of the entrance door and instead have a door which opens in the next room. Doing this will allow the fresh air inside the home making it well ventilated.
Have an entrance and an exit door:
The vastu principles suggest that there should be two doors; one for entry and another one for exit. The exit door should be smaller than the entrance door. This will let the fresh air enter in the home.
Points to be remembered:
  • Have the main entrance door as the largest door in your home.
  • The main door should be opened inside and should be clockwise.
  • Do not have self-closing doors.
  • The main door should have a threshold.
  • Do not have creaking doors.
For more details visit our website.
Regards:
2424
WHICH IS CORRECT LOCATION FOR MAIN DOOR
Last answer on 11/18/2013 4:15:10 PM. by S L Gupta (Civil Engg). Forum started by jjanmenjay
2079
main entrance of a home
Last answer on 4/29/2013 12:42:45 PM. by Amit Hasija. Forum started by SOUGAT KARMAKAR
2486
if the main entrance is south opening what is to be done
Last answer on 12/1/2021 12:04:35 PM. by Marta. Forum started by s.v.mahajan
2072
main entrance for house
Last answer on 5/19/2015 9:07:52 PM. by JAI PRAKASH. Forum started by charit
1803
main entrance for home
Last answer on 5/19/2015 9:07:45 PM. by JAI PRAKASH. Forum started by charit
1252
2622
Vastu of the attached flat
2496
Which is best location for main door in east facing plot as per the purvashadha
Last answer on 1/2/2021 5:22:27 AM. by Nageshwar. Forum started by Srinath
2289
our date of birth 17/08/1968 which we want put Main entrance Door Please tell me
Last answer on 1/5/2022 9:19:55 PM. by JAI PRAKASH. Forum started by Vasudev
2104
Bathroom door facing main entrance door in flat .can it be any problem?
Last answer on 7/16/2014 10:41:41 AM. by S L Gupta (Civil Engg). Forum started by ANURAG DUBEY
2287
my friends flat has east aagney main entrance door.please give the remedy for th
Last answer on 12/4/2013 2:47:20 PM. by S L Gupta (Civil Engg). Forum started by iangaswamy
3210
Door direction
Last answer on 7/3/2020 9:10:36 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
3086
2542
Door direction
Last answer on 6/28/2021 8:16:16 AM. by youtubevanced. Forum started by Rohit Patel
3697
about size of chowkets
1856
dear sir i have a plot of size 14*50 feet and i have a doubt that how many feet
Last answer on 2/17/2021 12:12:23 AM. by S L Gupta (Civil Engg). Forum started by barath kumar
1266
3406
3884
is it okay to have a toilet just next to the main gate/ entrance in the west dir
Last answer on 12/10/2009 12:07:55 AM. by juhi. Forum started by poonam_gunjiyal
3676
3086
2316
2345
3406
2265
5121
1845
7104
2554
2143
1723
1821
1833
2073
5822
2676
7305
7537
2704
Which are various sources of entrance for termites in a building?
The timber buried in ground. The means of mud shelter tubes constructed over unprotected foundations
Appropriate
Dining
Dining Room Vastu
Dining room should be comfortable and warm. It should be located in east or west direction, usually adjacent to the ki..
Pooja
Pooja Room Vastu
