I can not under stand about manufacturing process which you need to know, write in detail.
The shuttering plates are made from iron angles and iron sheets in the workshop either welded or rivitted. Some use wooden planks instead of shuttering plates.
The horizontal supports are either wooden battens or iron channels or girders.
The vertical supports are from salwood ballies or safeda ballies or iron pipes.
