Thu Feb 02, 2017
Yousuf
Topic: How many cement Sulphate and OPVC bags (50KG) required for 120 Sqryards (1080 sq
How many cement Sulphate and OPVC bags (50KG) required for 120 Sqryards (1080 sqft) ground floor construction and for Ground plus 1 floor construction?
Thu Feb 02, 2017
Dear Yousuf,
There is no any thumb rule for cement bags per sq feet but the cement bag i.e cement consumption is related to the plan of the building and specification used during construction.
Cement requirement
Last answer on 1/5/2022 12:58:42 AM. by
Yousuf
2303
Kindly suggest ground plus 1 map for 120 Sq yards east open plot
Last answer on 7/4/2020 4:21:37 AM. by
Yousuf
1603
How much Marole required
Last answer on 7/3/2020 11:26:58 PM. by
Yousuf
2555
Water for Construction
Last answer on 3/31/2010 6:05:23 AM. by
nuwan77
2085
help
Last answer on 1/9/2015 12:09:16 AM. by
Asif
1747
Last answer on 5/25/2016 11:08:08 AM. by
Dev
3501
Last answer on 1/10/2012 10:27:59 PM. by
op kataria
Shrinivas
2249
Metal,Cement & Jalli Requirement for RCC Slab Size 70'x26' = 1820
Last answer on 6/11/2016 12:26:27 PM. by
Mohan
2164
Last answer on 12/26/2014 1:19:11 PM. by
pramod Kumar patel
4076
steel requirement
Last answer on 7/4/2020 2:20:25 AM. by
Raghavendra
2439
Past Prices
Last answer on 11/23/2011 10:23:47 AM. by
ravi at Dalmia
Hemanth
1878
Last answer on 11/3/2016 10:40:18 AM. by
shashi
2278
swarup chakraborty
3097
cost of rcc roof
Last answer on 12/27/2013 11:59:27 AM. by
abdul wahid laskar
Last answer on 6/9/2016 11:04:10 PM. Forum started by
Vignesh
2871
Steel calculation
Vamshidharreddy
1997
Construction tender with design /vastu for around 120 sq yard plot in mathura anandvan
Last answer on 7/1/2013 4:32:46 PM. by
ALOK
3295
I have constructed a small house (120 Sq yards) having two bedrooms in south eas
Last answer on 10/12/2012 8:06:32 PM. by
krishna
Anuj Anand
2818
Last answer on 12/31/2020 2:51:38 AM. by
SHAILESH
AuStRalia!!CaNaDa" 91-9056562757 VASHIKARAN sPeCiAlIsT
Last answer on 1/1/2025 11:16:06 PM. Forum started by
Pandit Sahil Sharma Ji
Last answer on 1/1/2025 11:16:05 PM. Forum started by
Last answer on 1/1/2025 11:16:04 PM. Forum started by
Last answer on 1/1/2025 11:16:03 PM. Forum started by
Last answer on 1/1/2025 11:16:02 PM. Forum started by
Last answer on 1/1/2025 11:16:01 PM. Forum started by
Last answer on 1/1/2025 11:16:00 PM. Forum started by
Last answer on 1/1/2025 11:15:59 PM. Forum started by
Last answer on 1/1/2025 11:15:58 PM. Forum started by
Last answer on 1/1/2025 11:15:57 PM. Forum started by
Last answer on 1/1/2025 11:15:56 PM. Forum started by
Last answer on 1/1/2025 11:15:55 PM. Forum started by
Last answer on 1/1/2025 11:15:54 PM. Forum started by
Last answer on 1/1/2025 11:15:53 PM. Forum started by
Last answer on 1/1/2025 11:15:52 PM. Forum started by
Last answer on 1/1/2025 11:15:51 PM. Forum started by
Last answer on 1/1/2025 11:15:50 PM. Forum started by
Last answer on 1/1/2025 11:15:49 PM. Forum started by
What is acre
