Thu Aug 25, 2011Total posts : 1
BATHISHA
BATHISHA
Topic: how many cubic meter cement and sand is required to build a 10 square meter wall
how many cubic meter cement and sand is required to build a 10 square meter wall?block thickness 40*20*20 please help me
Mon Aug 29, 2011Post  #1
Dear Bathisha
 As per given size of block the cubical contents are 2cum and the cement required is 2bags and sand is .5 cum for the joints of wall.
Simple way for explain Cubic meter
Last answer on 2/18/2011 11:29:37 PM. Forum started by KS T9
13786
rcc rate per cubic meter
Last answer on 10/20/2014 12:03:29 PM. by S L Gupta (Civil Engg). Forum started by anks
2025
1786
3652
1647
Road Construction
Last answer on 9/13/2016 3:04:32 PM. by S L Gupta (Civil Engg). Forum started by Bharat Kumar
964
The plastering of roof top of my house has been damaged and water is seeping thr
Last answer on 11/13/2021 1:40:40 AM. by baba morris. Forum started by Priyadarshan
3792
1978
Transport
Last answer on 4/2/2016 12:12:42 PM. by S L Gupta (Civil Engg). Forum started by Bunkera1993
2260
Please suggest me the best map plan for 8×18 meter plan accordingly to vastushas
Last answer on 4/2/2017 6:08:24 PM. by praveenshiraguppe. Forum started by Ganesh Kumar
2753
i want details for a lobby decoration size 3*4 meters
Last answer on 7/3/2020 10:54:22 PM. by S L Gupta (Civil Engg). Forum started by adel
2069
beam and column
1941
Planning for new house construction
Last answer on 9/16/2015 4:01:37 PM. by Fahim. Forum started by Fahim
2422
3494
1767
1460
1449
Hi have a plot size of 5 x 11 Meter, can you suggest any best home plan with 1 e
Last answer on 7/4/2020 2:10:14 AM. by S L Gupta (Civil Engg). Forum started by ajit
5325
Setback or bylaws as per BDA
Last answer on 1/13/2011 7:17:31 PM. Forum started by ranjeeth
17
18
Results of 'Design A Dream Home' Competition
The results are following.
Orientation
Orientation of Building
