Sun Sep 25, 2016 | Total posts : 2 |
| Topic: maximum span between 10"x15", 10"x12", 10"x10" RCC columns
Hello guys! Please help me out, here are some of my Qs hope you guys will guide me right direction. Please check my house plan before you answer.
1.What would be the maximum span between 10"x15", 10"x12", 10"x10" RCC columns with 5" or 7" thick RCC floor slab and 3" ground floor slab?
2. 5"or7" thick, which RCC floor slab would work well with all three size columns mentioned above?
3. For 7" floor slab, would there be no floor beams(only hidden beams)?
4. What would be Beam (both Plinth and Floor beams) size/depth for all three size columns mentioned above? please mention the floor slab thickness.
5. What would be Footing size/depth for all three size columns mentioned above?
**Please see the attached floor plan(link added in the description) and please advice me, its a Two-story building with 10" exterior & 5" interior brick wall and a stair room on the second floor. |
Layout and House Plans-Construction Questions (39) | |
Articles that might interest you! | | Stair construction-Things to remember Stair construction needs major consideration while you are either building a new home or just doing any renovation. Th.. | | 10 tips to make a small space look bigger A small space looks tidy and large if items of daily use are organized properly in it. To create a spacious feeling, p.. | | Top 10 mistakes in Bathroom Design Bathroom requires careful planning otherwise you can face some big problems of water leakage, slippery floor and poor .. | | Top 10 mistakes in stairs design Most people do not realize the many choices they have for staircases. May be they do not know about the some mistake i.. | | Top 10 Mistakes to avoid when Hiring a Contractor When planning to build your dream home it may be difficult to hire a good contractor. A successful house construction .. | | Top 10 home decorating mistakes Home decoration is a very important thing, and our home should reflect our taste and personality. But we are making so.. | | 10 things to check before the rain hit your home! Rain is fun but the fun may not last if your home fails to protect itself and its occupants from the elements. This wr.. | | Column and Frame Structure Building Columns are used to support the beam or roofs and transfer the load to the earth. These serve the decorative purpose a.. | | RCC Roofing This roofing is very versatile and provides great protection. | | Tips for Laying RCC slab / roof RCC slab laying is one of major step in any type of construction so it is mandatory to know all the points related to .. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
