method of road structure, step wise detail caculation of material
Tue Mar 15, 2011Total posts : 5
kanwer sajjad
kanwer sajjad
Topic: method of road structure, step wise detail caculation of material
Fri Mar 18, 2011Post  #1
Dear Kanwer
           There are many steps which are followed during construction of road.
1 Jungle clearance.
2 Demarcation of centre line.
3 Lay out
4Earth work.
5 Compaction of earth work.
6Dressing sub grade.
7. Laying edging
8 Laying soling coat.
9 Wearing coat
10 Finishing coat as per requirement.
Fri Mar 18, 2011Post  #2
kanwer sajjad
kanwer sajjad
Post subject: road construction
hi sir ,
          laying edging and dressing sub grade method  plz help me.
Fri Mar 18, 2011Post  #3
Dear Kanwer
1 After compacting the earth work, the top layer of earth work is dressed to the level required with proper gradient and camber. After dressing the surface is rolled with road roller.
2. After preparation of sub grade brick edging is laid on both edges of road to protet the road material filled in the road and also protect the edge.
Fri Mar 18, 2011Post  #4
kanwer sajjad
kanwer sajjad
Post subject: sewerline
hi sir,
        thanx my question is related sewer line , excevation  rail method in sewerage.
Fri Mar 25, 2011Post  #5
kanwer sajjad
kanwer sajjad
Post subject: bridge
hi sir,
       explain parts of  RCC bridge.
Last answer on 12/31/2020 2:22:44 AM. by Mani . Forum started by bhavika
staircase ,step & riser
Last answer on 8/6/2011 2:49:12 PM. Forum started by shabbir ali
2797
4925
LOAD BEARING STRUCTURE
3610
2033
2722
Kindly assist with step by step procedure of building a Duplex.
Last answer on 12/31/2020 2:07:47 AM. by Gunjan Utraja. Forum started by Tuneer Garga
2330
1762
Dear Gupta sir,i am ready to get a detailed estimate for my house to be construc
Last answer on 5/4/2013 2:25:17 PM. Forum started by nithun
2536
932
any new methods for quick construction ??
Last answer on 7/3/2020 10:05:55 PM. Forum started by PAVAN K
2629
25*18south facing house with bedroom,toilet kitchen and hall with steps
Last answer on 11/13/2017 1:46:28 AM. by S L Gupta (Civil Engg). Forum started by Harish
1461
DOES HAVING STEPS IN THE HOUSE EFFECT IN ANY WAY?
Last answer on 8/8/2017 12:10:09 PM. by S L Gupta (Civil Engg). Forum started by MADHU
1455
Steps was constructed in south West corner of my house .is it correct
Last answer on 8/8/2017 12:09:44 PM. by S L Gupta (Civil Engg). Forum started by Raja
3031
Last answer on 4/1/2013 3:23:48 PM. by akmurty1. Forum started by kjeevanrao
2244
how many steps made at home.
Last answer on 7/4/2012 8:11:12 AM. by Amit Hasija. Forum started by Saurabh
1749
vastu for steps please
Last answer on 1/9/2014 11:02:06 AM. by S L Gupta (Civil Engg). Forum started by lakshmi
5929
Last answer on 7/4/2020 2:13:40 AM. by JAI PRAKASH. Forum started by P Pavan Kumar
2052
17
How to Build Stair Steps
Earthquake
What preliminary steps should be taken before terrazzo tile flooring?
If any tile is not in perfect square shape, it will spoil the entire flooring.
How to Install a Sink
Installation of kitchen sink requires just few tools,material and a beautiful sink according to your needs. Read the s..
